Home > Puma (Tdci) > ABS T/C lights on
skyeplumb
Scotland 2007 Defender 110 Puma 2.4 USW Rimini Red
ABS T/C lights on
Hi, i know this has been covered before, but what i need and can't find is a copy of the technical bulletin LTB00078v2/2007.
does anyone have a copy?????
2007 110 Utility - only bought it 3 days ago Big Cry
I've looked at the cables - all appear to be OK, the earth on the battery is good and the connection to the chassis & engine appears fine. lights come on after a few minutes driving - can't pin it down to speed / turning / bumps etc.
Any ideas much appreciated...
Clive Series IIa Lightweight - Long Gone
Discovery 1 300Tdi - Sold
Defender 110 XS 07MY Utility
Post #231832 30th Apr 2013 7:42pm
The usual causes are a poorly seated sensor, chaffed cables or worn wheel bearings. A diagnostic tool of some description can narrow it down to a particular wheel so you know where to look. Darren
Post #231881 30th Apr 2013 9:58pm
skyeplumb
Thanks Darren, ill take it back to the dealers (400 mile round trip)
Post #231926 1st May 2013 7:39am
Blimey, I don't envy you that Shocked Darren
Post #231931 1st May 2013 7:55am
K9F
http://www.defender2.net/forum/topic2394.html?highlight=abs If you go through life with your head in the sand....all people will see is an ar5e!!
Post #231943 1st May 2013 9:00am
MartinK
Clive
I assume that's Macrae & Dick in Inverness ??? Good guys - they'll get you sorted Thumbs Up Tough trip though, a whole tank of diesel for a repair... Crying or Very sad Did you get a LR warranty? could you call Land Rover Assistance to save the diesel? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #231954 1st May 2013 9:25am
skyeplumb
MartinK wrote:
Clive
unfortunately not- it came from Lix Toll in Perthshire - I'm just waiting for them to call me back - I emailed them a list of problems with it that I have discovered after only having it since friday...Big Cry time to find out if they are a good dealer - i do hope so.
and thanks K9F - i've seen the other posts regarding the same problem, that what lead me to check wiring / earths etc. Series IIa Lightweight - Long Gone
Post #231957 1st May 2013 9:48am
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
I bought mine about a month ago and have this same problem, checked on here and so checked multi plugs and a visual on all the abs cables underneath and the earth cables. Car has done 21,000 miles (08 plate) and three lights come on as soon as i start it (started off intermittently but has got worse over time).
If you work out the problem let me know Rolling Eyes William
Post #231995 1st May 2013 1:05pm
MartinK
I believe they have a good reputation, they've been in the game a long time Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #231998 1st May 2013 1:34pm
skyeplumb
well - it's back at Lix Toll, they are having it for a couple of days as there are other issues.
one thing I did notice today, was that after I filled up with diesel, the ABS & TC light took a lot longer to appear????? Series IIa Lightweight - Long Gone
Post #232244 2nd May 2013 3:21pm
K9F
Mine was 'weather dependant' itnitially the fault only occured when the conditions were wet which then provided an electrical path for the cable to ground to earth. As time progressed the fault manifested itself more and more as the chafed cable got worse. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #232253 2nd May 2013 4:33pm
Merlin
I had this as well. Repaired under warrantee. Dealer said there was a bit of metal stuck between contacts on the ECU thingy. Hope this helps.
Merlin
Post #232261 2nd May 2013 5:37pm
william8
Bad news for myself, No warranty Sad
Does anyone know what specific loom it is that is common to rubbing through ? William
Post #232352 3rd May 2013 12:00am
K9F
Read the link I posted there's a couple of pointers there. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #232396 3rd May 2013 10:10am
skyeplumb
Garage have just phoned to say that they can't find a problem with it - they have checked the wiring, the sensors, earths etc as per the technical bulletin - all OK EXCEPT the lights keep coming on! with nothing logged in the computer - they are phoning LR in the morning to see what else it could be.
Hope this get resolved soon as I paid a lot of money for a car that I've owned for 12 days and for 6 of those it's been back in the garage Big Cry
At least my trusty old 300TDi Disco is keeping me mobile. Series IIa Lightweight - Long Gone
Post #233139 6th May 2013 5:15pm
