![]() | Home > Puma (Tdci) > ABS T/C lights on |
skyeplumb Member Since: 22 Apr 2013 Location: Isle of Skye Posts: 134 ![]() ![]() ![]() |
Hi, i know this has been covered before, but what i need and can't find is a copy of the technical bulletin LTB00078v2/2007.
does anyone have a copy????? 2007 110 Utility - only bought it 3 days ago ![]() I've looked at the cables - all appear to be OK, the earth on the battery is good and the connection to the chassis & engine appears fine. lights come on after a few minutes driving - can't pin it down to speed / turning / bumps etc. Any ideas much appreciated... Clive Series IIa Lightweight - Long Gone Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility |
The usual causes are a poorly seated sensor, chaffed cables or worn wheel bearings. A diagnostic tool of some description can narrow it down to a particular wheel so you know where to look. Darren
Thanks Darren, ill take it back to the dealers (400 mile round trip)
Cheers Clive Series IIa Lightweight - Long Gone Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility |
Blimey, I don't envy you that
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
http://www.defender2.net/forum/topic2394.html?highlight=abs If you go through life with your head in the sand....all people will see is an ar5e!!
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2666 ![]() ![]() ![]() |
I assume that's Macrae & Dick in Inverness ??? Good guys - they'll get you sorted ![]() ![]() |
unfortunately not- it came from Lix Toll in Perthshire - I'm just waiting for them to call me back - I emailed them a list of problems with it that I have discovered after only having it since friday... ![]() and thanks K9F - i've seen the other posts regarding the same problem, that what lead me to check wiring / earths etc. Series IIa Lightweight - Long Gone Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility |
I believe they have a good reputation, they've been in the game a long time ![]() |
well - it's back at Lix Toll, they are having it for a couple of days as there are other issues.
one thing I did notice today, was that after I filled up with diesel, the ABS & TC light took a lot longer to appear????? Series IIa Lightweight - Long Gone Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility |
Mine was 'weather dependant' itnitially the fault only occured when the conditions were wet which then provided an electrical path for the cable to ground to earth. As time progressed the fault manifested itself more and more as the chafed cable got worse. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
I had this as well. Repaired under warrantee. Dealer said there was a bit of metal stuck between contacts on the ECU thingy. Hope this helps.
Merlin |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
Bad news for myself, No warranty
![]() Does anyone know what specific loom it is that is common to rubbing through ? William |
Read the link I posted there's a couple of pointers there. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Garage have just phoned to say that they can't find a problem with it - they have checked the wiring, the sensors, earths etc as per the technical bulletin - all OK EXCEPT the lights keep coming on! with nothing logged in the computer - they are phoning LR in the morning to see what else it could be.
Hope this get resolved soon as I paid a lot of money for a car that I've owned for 12 days and for 6 of those it's been back in the garage ![]() At least my trusty old 300TDi Disco is keeping me mobile. Series IIa Lightweight - Long Gone Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility |
