Home > Puma (Tdci) > Can Pumas do PTO?
BigWheels
Can Pumas do PTO?
Someone I know has offered to sell the PTO winch from his 300TDi. Can Pumas run PTO tools?
If not, what was the last model of Defender that could? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #182696 6th Nov 2012 9:09pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Don't know about Puma's but my TD5 is running a PTO Thumbs Up 2007 TD5 90 Hard Top
Post #182734 6th Nov 2012 10:35pm
drive4change
United Kingdom 1993 Defender 130 200 Tdi HCPU Alpine White
What winch are you using with your pto landlord?
Post #182735 6th Nov 2012 10:36pm
Landlord
Red Terrier, great piece of kit. 2007 TD5 90 Hard Top
Post #182737 6th Nov 2012 10:40pm
drive4change
Hmmm. Have taken a quick look at those. Made locally too. May have a more in depth look. Thumbs Up
Post #182739 6th Nov 2012 10:42pm
speedymarktd6
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Epsom Green
Not an exact answer but we get relatively new transits in from utility companys and they have pto generators and compressors on them so i would say yes you can but i dont no who does them
Post #182743 6th Nov 2012 10:54pm
Landlord
Try Peter at First Four, supplies everything you need to install a PTO, control valve, solenoid, winch, standard and made to measure hydraulic tank, etc
http://www.firstfour.co.uk/ 2007 TD5 90 Hard Top
Post #182747 6th Nov 2012 11:01pm
The transfer box is still the LT230, and I can't imagine they've changed the internals that much from a well proven working design, so woudl have thought that the PTO would still work,
Post #182876 7th Nov 2012 3:25pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
At a different angle though and slightly further back Original Member Pie n Pea Club.
110 HCPU Tipper
Post #182885 7th Nov 2012 4:11pm
noworries4x4
The hand throttle mod for the Puma is horrendusly expensive, and no you cant use a stick ive tryed If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #183046 7th Nov 2012 10:21pm
GREENPUMA
United Kingdom 2007 Defender 110 Puma 2.4 SW Keswick Green
Tdci definitely no probs with PTO, it's the same LT230 Transfer box.
http://www.firstfour.co.uk/products/hydrau...ive-system
Post #193550 14th Dec 2012 8:17pm
willy eckerslike
So would need checking first Original Member Pie n Pea Club.
110 HCPU Tipper
Post #193567 14th Dec 2012 9:37pm
Christian
Qatar 2008 Defender 90 Puma 2.4 SW Java Black
Hello there,
I'm having my transfer box replaced on my Puma, and the question whether to fit it with PTO dog teeth has been raised...
I still can't read a strictly positive or negative answer about the feasibility of it on Pumas.... except there :
PTO for TDCI
Nakatenga claiming it's a no go...
Any confirmation ? Chris
Post #228388 18th Apr 2013 5:29am
willy eckerslike
You can by a PTO Hydraulic kit for pumas on ebay, it fits where the Aircon goes and is belt driven which is probably better than transfer box. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #228409 18th Apr 2013 7:28am
I have never understood why the hand throttle for a Puma (or a TD5 for that matter) is so expensive, since with fly-by-wire and an ECU technically it should be failry simple (especially if you don't have to decompile the ECU data to produce it). I can only assume that since unit sales are so low and mainly to utility companies etc who'll pay well over the odds, LR can get away with it.
Perhaps there's an opportunity for one of our remap magicians to come up with something affordable.
Post #228426 18th Apr 2013 8:20am
