![]() | Home > Puma (Tdci) > Can Pumas do PTO? |
| Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582
Don't know about Puma's but my TD5 is running a PTO
| drive4change Member Since: 15 Aug 2012 Location: Somerset Posts: 193
What winch are you using with your pto landlord?
Red Terrier, great piece of kit. 2007 TD5 90 Hard Top
Hmmm. Have taken a quick look at those. Made locally too. May have a more in depth look.
| speedymarktd6 Member Since: 02 May 2011 Location: Worcestershire Posts: 102
Not an exact answer but we get relatively new transits in from utility companys and they have pto generators and compressors on them so i would say yes you can but i dont no who does them
Try Peter at First Four, supplies everything you need to install a PTO, control valve, solenoid, winch, standard and made to measure hydraulic tank, etc
http://www.firstfour.co.uk/ 2007 TD5 90 Hard Top |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
The transfer box is still the LT230, and I can't imagine they've changed the internals that much from a well proven working design, so woudl have thought that the PTO would still work,
| willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789
At a different angle though and slightly further back Original Member Pie n Pea Club.
110 HCPU Tipper |
| noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196
The hand throttle mod for the Puma is horrendusly expensive, and no you cant use a stick ive tryed If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
| GREENPUMA Member Since: 12 Feb 2010 Location: devon Posts: 17
Tdci definitely no probs with PTO, it's the same LT230 Transfer box.
http://www.firstfour.co.uk/products/hydrau...ive-system |
So would need checking first Original Member Pie n Pea Club. 110 HCPU Tipper |
| Christian Member Since: 23 Feb 2013 Location: Doha Posts: 66
Hello there,
I'm having my transfer box replaced on my Puma, and the question whether to fit it with PTO dog teeth has been raised... I still can't read a strictly positive or negative answer about the feasibility of it on Pumas.... except there : PTO for TDCI Nakatenga claiming it's a no go... Any confirmation ? Chris |
You can by a PTO Hydraulic kit for pumas on ebay, it fits where the Aircon goes and is belt driven which is probably better than transfer box. Original Member Pie n Pea Club.
110 HCPU Tipper |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038
I have never understood why the hand throttle for a Puma (or a TD5 for that matter) is so expensive, since with fly-by-wire and an ECU technically it should be failry simple (especially if you don't have to decompile the ECU data to produce it). I can only assume that since unit sales are so low and mainly to utility companies etc who'll pay well over the odds, LR can get away with it. Perhaps there's an opportunity for one of our remap magicians to come up with something affordable. |
