![]() | Home > Technical > Nanocom and defender 90 TD5 1998 |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
If your car is an early car, and this is your vin number on the sticker its an early MSB ecu.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727 ![]() ![]() ![]() |
A "3Axxxxxx" chassis number should be a NNN ECU (post 2002MY)
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
Hi Martin.......this is the ECU currently in my defender 90 TD5 1998? So do you think it may have a newer ECU from the pics you see? Only had it 5 days so not sure whats what yet ![]() |
Is it your chassis number on the ecu ?
which is the chassis number.....nothing matches my VIN, are `VINS safe to post ?
from the ecu lable in your picture, it looks like its not your original ecu.
SALLDVA573AEDITED Vehicle: Defender / L316 Model year: 2003 Build date: 19-Nov-2002Selling dealer: C1880Warranty start date: 13-Jan-2003 Image for illustration purposes only.Outstanding Campaigns: There are currently no outstanding Campaigns for this vehicle Vehicle featuresEmission requirements: 2000EC CAR REQTS Engine: 2.5L I5 TI SOHC DIESEL MP EFI Drive: 4 WHL R/H FULL TIME DRIVE CAB style: SINGLE CAB (REGULAR CAB) Transmission: R380 M5 - 5 SPD MAN TRANS LR Colour: CHAWTON WHITE SOLID |
No that's not my 1998 TD5 in woodcote green
So does that mean I have a remapable ECU?
It does look that way yes, though to confirm exactly the sticker on the end will verify it. 3 8mm headed bolts and its out. Fingers crossed it has the correct calibration for the EU2 engine in as we'll as your injector codes to match and its not just been cobbled on by the previous owner!
Pete |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
Pete, sorry to hijack the thread.
If a flashable ECU (later NNN type) is used on an earlier (10P) engine, as you say it needs the correct EU2 calibration. Is this calibration a different "thing" to the actual fuelling file... so if a later NNN ecu is given the correct EU2 calibration can other fuelling files be flashed to the ECU (if for example, one had a nanocom and a handful of different tunes they were playing with), Or, is the calibration part of the main fuelling file too? so the two files... calibration and fuelling, are "together" cheers ![]() |
Given it may be a newer NNN ECU would it now be worth me buying a nanocom and programming my own remaps? Not sure what the whole story is re programming yet
The calibration is the main fueling mapas you ask and yesit can bechanged and programed with Nanocom in a standard or tuned format to the ecu.
Nanocom use a single file which is ajoint software and calibration file in one. Johdnyd, yes its an option you can use if you wish but would work out expencive just for a remap. Pete |
Gotcha, thanks Pete, makes sense now. |
