Home > Technical > Nanocom and defender 90 TD5 1998
Page 3 of 3 <123
johnnyd
ok i have had the ECU out and can confirm it is nnn000120
Post #228548 18th Apr 2013 2:31pm
bell-auto-services
EU2 flashable then Thumbs Up
Post #228614 18th Apr 2013 5:44pm
Pete, this NNN000120 was used in disco and defender wasn't it?
is it a one time flashable (set at the factory) for defender or disco? or can they be reflashed (say, with a nanocom file) to convert it from a disco to a defender spec one?
I think I know where I can lay my hands on one for my 90 (10p engine)
Post #228615 18th Apr 2013 5:48pm
bell-auto-services
It was used both on the Defender and D2, the calibration was changed depending on application, the nanocom will program or swap to what ever model is needed for the manual D2 or Defender.
only MSB part numbers are OTP.
Post #228617 18th Apr 2013 5:56pm
Excellent. cheers.
Post #228618 18th Apr 2013 6:03pm
johnnyd
Pete how much are your Nanocoms ? Also if i now have EU2 ECU does the remap you provide fit all for stage 1, or if brought in to the workshop, are they 'tuned' to each vehicle?
Post #228621 18th Apr 2013 6:10pm
bell-auto-services
The nanocom is priced on my web site with different options, you can also buy it direct from blackbox solutions in Cyprus.
The maps it writes are dependant on what map you select to use in its software, it may be that your ecu is flashable but it still does need a correct eu2 map programming on it, nanocom will do this for you.
My tuned files are for each car dependant on the car, customer needs and software version supplied to me for tuning.
Pete
Post #228771 19th Apr 2013 8:50am
landyman37
Hi Pete
If I had a remap for my nano com could I put it on more than one vehicle as we have a defender 110 and a disco 2
Phil
Post #229280 21st Apr 2013 10:10am
bell-auto-services
Hi
No the remap for the nano com is per car, the discovery and the defender for sure will also use a totally different software calibration and would never be compatible with each other.
Pete
Post #229326 21st Apr 2013 12:07pm
Page 3 of 3 <123
