Home > Technical > Nanocom and defender 90 TD5 1998 |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
ok i have had the ECU out and can confirm it is nnn000120
18th Apr 2013 2:31pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
EU2 flashable then
18th Apr 2013 5:44pm |
It was used both on the Defender and D2, the calibration was changed depending on application, the nanocom will program or swap to what ever model is needed for the manual D2 or Defender.
only MSB part numbers are OTP. |
18th Apr 2013 5:56pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6043 |
Excellent. cheers.
18th Apr 2013 6:03pm |
Pete how much are your Nanocoms ? Also if i now have EU2 ECU does the remap you provide fit all for stage 1, or if brought in to the workshop, are they 'tuned' to each vehicle?
18th Apr 2013 6:10pm |
The nanocom is priced on my web site with different options, you can also buy it direct from blackbox solutions in Cyprus.
The maps it writes are dependant on what map you select to use in its software, it may be that your ecu is flashable but it still does need a correct eu2 map programming on it, nanocom will do this for you. My tuned files are for each car dependant on the car, customer needs and software version supplied to me for tuning. Pete |
19th Apr 2013 8:50am |
landyman37 Member Since: 22 Jan 2012 Location: west midlands Posts: 153 |
Hi Pete
If I had a remap for my nano com could I put it on more than one vehicle as we have a defender 110 and a disco 2 Phil |
21st Apr 2013 10:10am |
Hi
No the remap for the nano com is per car, the discovery and the defender for sure will also use a totally different software calibration and would never be compatible with each other. Pete |
21st Apr 2013 12:07pm |
