![]() | Home > Puma (Tdci) > How to remove steering wheel |
| adiep Member Since: 18 Nov 2012 Location: Gibraltar Posts: 204
Can anyone clue me in on how to remove the steering wheel. I removed a giant nut and it still seems to be stuck, is there anything else needed?
also, I need to replace the light switch and unded all the screws on the steering column, and the damn plastic wont come off... presume i do need to remove the steering wheel so i can replace those swicthes? to top it all off... whilst trying to do all the above, i locked the keys in the car and had to smash the damn window |
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
To remove the wheel undo the centre nut but DO NOT take it off fully.
Then hit the wheel in the 9 and 3 o'clock positions alternately with your hands from the underside. The nut still being attached will stop the wheel from flying off and hitting you in the face when it breaks free. Just removed mine on the new 90 and actually hit it on the front a couple of times and it broke free. You should be able to replace the switches with the wheel on but it is easier with it removed. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Will have another stab. But I removed 4 screws from the black plastic column thing and its loose but wont come off... wobbles around but wont come off !!! grrrr |
Have you removed the bottom screw, it's a pig to get out, fifth picture down in this thread
http://defender2.net/forum/topic17090.html Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
whaaaaaaaaaaaaaaaaaaaah thanks.... let me try that tomorrow. I guss that will do it |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
YOU DON'T NEED TO REMOVE IT! From further down in the same thread. Also there is no need to remove the screw above the parcel shelf with mole grips as this is there only to align up the cowl and is not attached to the bottom cowl which comes off over it. I also removed the cowl without the need to extract this screw when fitting my barrel lock. Treat every day as if it is your last....one day you will be right!! |
| superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314
Get one of these
http://www.ebay.co.uk/itm/Landrover-specia...1c31c7f0bb Saves loads of hassle ( and broken nose's) Superspoons |
| All times are GMT |
