Home > Puma (Tdci) > cooling issues with lightforce 240 ?
billewizz
Has anyone had issues with cooling on a puma when running with lightforce 240 on a factory A bar, i found it hard to believe but thought i would ask before taking the plunge.
Post #227249 14th Apr 2013 6:25pm
K9F
Not at all! Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #227282 14th Apr 2013 7:21pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
I took mine down to Italy in some hot weather and had no problems, but I did wonder if the lack of air flow affects the performance by the inter cooler not getting the full airflow. May be its another test for Pete to try on the rolling road.
Post #227285 14th Apr 2013 7:31pm
billewizz
it was seeing yours that set me off on this route so its come back from the hourses mouth, i found it hard to believe when the dealer I was trying to buy them from surgested it.
Thanks K9F
Post #227286 14th Apr 2013 7:34pm
K9F
Welcome. Thumbs Up
I have a Scangauge II and have had it fitted since before the Lightforces were, it made no discernable difference in the running temperatures that I could notice. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #227291 14th Apr 2013 7:52pm
Off Topic Looks great as always Mal. Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #227295 14th Apr 2013 7:57pm
K9F
Thanks Steve. Fancy knowing how much my wish-list has cost to date? Shocked
Too bl00dy much at £14,177:50 me thinks! If SWMBO knew she'd go orbital! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #227305 14th Apr 2013 8:15pm
"Going Orbital"
Rolling with laughter Rolling with laughter Rolling with laughter ____\We|Will|Win/___
Post #227306 14th Apr 2013 8:17pm
K9F
Shshshshshshshshshsh! Thumbs Up Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #227308 14th Apr 2013 8:18pm
Glynparry25
Just for further peace of mind.... I am running the Lightforce 240s and a winch bumper which is even more restrictive than a LR A-bar, and the temperature this last summer was knocking on 40 DegC every day with no ill effects:
Glyn Dog :sheep:
Post #227316 14th Apr 2013 8:33pm
GUM97
I'm assuming that's without the initial purchase price? Thumbs Up An engine to TDi for!
Post #227317 14th Apr 2013 8:34pm
smb
Thanks K9F
I ran all last year with 240's in addition to winch and A-Bar and it made no difference whatsoever. Plus there is AirCon and a fully insulated bonnet.
Just for reference, in addition to the above I also have a Radiator Muff on at the moment with only a small opening and it still doesn't make a difference.
I don't suppose this 'dealer' didn't have 240's in stock, but was trying to persuade you to go for 170's or 140's instead?!
Post #227320 14th Apr 2013 8:55pm
JeremyJ
Glyn Dog Sheep
OT - I love that photo!
Post #227321 14th Apr 2013 8:55pm
John110
Ireland 2007 Defender 110 Puma 2.4 HT Stornoway Grey
That settles it, I'm taking off the ARB bar and winch and going for that Soft A bar and lightforce set up.
It just looks sweet Thumbs Up
John For those who understand, no explanation is needed...
For those who do not understand, no explanation is possible
Post #227329 14th Apr 2013 9:19pm
x-isle
When you think about it. The Defender has been designed (was it actually designed?????) to be running off-road at slow speeds under heavy load.
It doesn't get a high volume of fast flowing air under those conditions, so some spots in front isn't going to make much of a difference. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #227357 15th Apr 2013 5:55am
