![]() | Home > Puma (Tdci) > cooling issues with lightforce 240 ? |
Not at all!
![]() ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 714 ![]() ![]() ![]() |
I took mine down to Italy in some hot weather and had no problems, but I did wonder if the lack of air flow affects the performance by the inter cooler not getting the full airflow. May be its another test for Pete to try on the rolling road.
billewizz Member Since: 16 Sep 2011 Location: north lincs Posts: 68 ![]() ![]() |
it was seeing yours that set me off on this route so its come back from the hourses mouth, i found it hard to believe when the dealer I was trying to buy them from surgested it. Thanks K9F |
Welcome.
![]() I have a Scangauge II and have had it fitted since before the Lightforces were, it made no discernable difference in the running temperatures that I could notice. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Thanks Steve. Fancy knowing how much my wish-list has cost to date? ![]() Too bl00dy much at £14,177:50 me thinks! If SWMBO knew she'd go orbital! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
"Going Orbital" ![]() ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Shshshshshshshshshsh!
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Just for further peace of mind.... I am running the Lightforce 240s and a winch bumper which is even more restrictive than a LR A-bar, and the temperature this last summer was knocking on 40 DegC every day with no ill effects:
[URL=] ![]() Click image to enlarge[/URL] Glyn ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
I'm assuming that's without the initial purchase price? ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
I ran all last year with 240's in addition to winch and A-Bar and it made no difference whatsoever. Plus there is AirCon and a fully insulated bonnet. Just for reference, in addition to the above I also have a Radiator Muff on at the moment with only a small opening and it still doesn't make a difference. I don't suppose this 'dealer' didn't have 240's in stock, but was trying to persuade you to go for 170's or 140's instead?! |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
OT - I love that photo! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106 ![]() ![]() ![]() |
That settles it, I'm taking off the ARB bar and winch and going for that Soft A bar and lightforce set up.
It just looks sweet ![]() Cheers John For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
When you think about it. The Defender has been designed (was it actually designed?????) to be running off-road at slow speeds under heavy load.
It doesn't get a high volume of fast flowing air under those conditions, so some spots in front isn't going to make much of a difference. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
