![]() | Home > Maintenance & Modifications > springs |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
last time I fitted any springs to a car it was sat on a couple of 40 year old home made wooden tressels, clearly this isn't an option with the defender (the tressels are good, but not that good).
so being on the verge of a numpty (I do at least appreciate the standard bottle jack under the axle isn't gonna get me where I want), so what kit do I need and where to replace rear springs........ please don't ask why |
| appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630
A long reach jack, and tall axle stands, spring compressors, and wheel chocks. Would be my recommendation.
damn. got none of those....well can probably do the chocks.
anyone know how high the axles stands need to be and where to located them? many thanks. |
Ok, the way I'd do a REAR spring:
Handbrake on, chock front wheels. Remove rear wheel. Spring compressor on, and remove spring retainer. Jack vehicle up by chassis, using axle stands to make safe as you go. Old Spring out, new spring compressed, retainer fitted. Let compressor out as much as dared. Lower chassis back down, examining spring seating as you go. I hope this helps, others may be along to advise better or different methods. I've made the assumption that you are capable, and have more than an ounce of common sense, with regards to lifting heavy vehicles, and using tools. |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
Probably safer too as with the wheel still on it would have less distance to drop and also the brake disc / axle wouldn't go flat on the floor if the jack gave way... ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
Just remembered though.
WATCH THE BRAKE PIPE (from body to axle). The springs will come loose before it gets tight, but still keep an eye on it just to be sure Glyn |
| bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189
If you have a stiff ARB might also undo the brackets to aid with articulation re spring removal. Worked well for me and no need for a spring compressor. BM52
| All times are GMT |
