Home > Maintenance & Modifications > Boost alloy Wheelnuts Siezed?
macduff
Came to trail fit some alloy wheels I've located for my 110XS and couldn't get the rear axle wheel nuts off Sad
They are on so tight I bent my draper 1/2" drive T-bar and the LR oem Wheel nut bar.
Common problem? I wonder if they have never been off since new , though fronts came undone with reasonable force/nice cracking sound.
Got a 1" drive Impact socket and breaker bar coming to my aid but wondered if a rattle gun is the best bet before resorting the to scaffold pole Olympics 2023 110 P400e
Post #225401 8th Apr 2013 12:06pm
K9F
Scaffolding pole over rattle gun as the force applied to achieve the goal can be more controlled is my personal view.
Good luck! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #225403 8th Apr 2013 12:08pm
GUM97
Try a windy gun, but they don's always work Confused How many are stuck on? An engine to TDi for!
Post #225404 8th Apr 2013 12:09pm
ibexman
Ive resorted to a jack on to wheel brace that usually does the trick Thumbs Up
Post #225414 8th Apr 2013 1:24pm
macduff
All the standard nuts on the rear axle Sad, not tried the lockers with any great force yet as don't want to burr the the locking seat with a hamfisted attempt using my now bent nut wrench or T-bar. Glad I found out now and not the hard way with a flat on a lane Shocked Maybe one for all "new" to them defenders owners to check asap (or give it back to dealers to sort). 2023 110 P400e
Post #225416 8th Apr 2013 1:24pm
If you have factory fit locking wheel nuts then don't use a windy gun on them, especially if they have been brutally overtightened (and it sounds like yours have). If you do, the "key" will split.
If your nuts have been drastically overtightened, check the studs for 'necking' before refitting (replace any that appear in any way damaged) and consider replacing the nuts, you really don't what the wheel overtaking you on the road.
When refitting, smear copper grease over the contact surface between the wheel and the hub, the studs, and the contact faces on the nuts. Then use a torque wrench to tighten them (98lbfft, if I recall). You will be surprised how un-tight this actually is (you can easily do them up properly with a good quality 3/8" sq dr socket without risking the tool).
For some reason wheel nuts and spark plugs have always been victim to people who seem to think that the tighter they are done up the better! Cretins.
PS - if you have (or have access to) one, one of the traditional "spiders" is great for undoing these nuts, especially the lockers, since it is easy to apply a true torque to the nut without any radial force (which is very difficult to avoid with a single-arm tool). Highly recommended.
Post #225417 8th Apr 2013 1:27pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
When my nuts are tight ( Shocked ) I put an axle stand under the wheel wrench, as close as possible to the nut. This helps avoid any radial forces, especially on the locking nuts. As was said in the previous post, a spider wrench is a good investment too.
Good luck.
Simon
Post #225437 8th Apr 2013 3:17pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Almost in agreeance with blackwolf - apart from copper slip/grease on the wheel studs.
Professional practice is clean and dry thread, no lubrication. No ifs or buts. Manufacturer torque specs are for unlubed threads unless otherwise specified.
The 'copper slip or not' issue on wheel studs is a real can of worms in professional circles lol Whistle Guns and Landrovers .... anything else is irrelevant.
Post #225444 8th Apr 2013 3:47pm
Seldom has a truer word been written!
Post #225447 8th Apr 2013 4:02pm
couplands
I think the advice about copper grease was for the contact surfaces, not the thread....if that makes a difference...?
Simon
Post #225457 8th Apr 2013 4:34pm
GUM97
In my workshop (HGVs), use Copper grease on a wheel nut and I'll sack you, on the spot. I've seen too many wheels lost due to copper grease, so it really is a no no as far as I'm concerned. An engine to TDi for!
Post #225470 8th Apr 2013 5:06pm
For a period of over 10 years the Land-Rover handbook supplied with new vehicles instructed that when you had removed a wheel you should put a drop of oil on each stud to facilitate future removal.
I thought it instructed thus and have just checked to ensure my memory wasn't playing tricks. Although LR no longer says this, the technology hasn't changed especially with steel wheels.
For the record, although I do this on my LR wheels I don't on my larger vehicles and never on duallies, never on multi-axles.. I check all wheel nut torques frequently and regularly.
If in doubt I suggest (as mentioned above) minimal antiseize on the surfaces that contact the wheel but not the thread, keep this clean and dry.
Post #225474 8th Apr 2013 5:30pm
IF and I mean IF all else fails tighten them up a BITthen try to undo
Really a last resort as hub damage is possible
Good luck Thumbs Up
Post #225478 8th Apr 2013 5:38pm
macduff
Won't get my breaker bar and deep socket until later in the week but on a positive note the locking nut on the offside rear wheel was torqued to the correct spec and came undone ok. Will need to turn it around to check the nearside as its close against a wall. Slightly confused (maybe not) as to why a numpty would wind the normal ones on like a gorilla then get the locking ones on correctly hey ho.
As an aside its been serviced annually regardless of mileage by the local LR dealers by the previous owner Confused so not sure I'd put any weight on a full dealer service history from a certain dealer group. 2023 110 P400e
Post #225496 8th Apr 2013 6:37pm
It may be that the lockers were tightened by hand but the others were windy-gunned.
Post #225513 8th Apr 2013 7:37pm
