Home > Puma (Tdci) > Door seal
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Door seal
Looking down from the drivers seat (and passenger) I can see the road through the bottom rear corner of the door, is this standard or have I got badly fitted seals?
Wondered why I was getting a cold draught Banging Head
Cheers Darren
Post #225265 7th Apr 2013 7:13pm
Delskinz
England 2007 Defender 110 Puma 2.4 SW Tonga Green
From the inside looking at the bottom left of all the doors I see a small section where I see light too.
Post #225278 7th Apr 2013 7:33pm
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
I'll check mine tomorrow, too late to see daylight now! 2.2 90 XS
88" Series One
Old Norton Smile
Modern Honda and Harley
Post #225303 7th Apr 2013 8:48pm
Happyoldgit
Yes pretty common on the old type door seals especially when the little self adhesive rubber blocks in the corners drop off. The newer type seals follow the door contours better. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #225317 7th Apr 2013 9:32pm
Sonarmender
England 2015 Defender 90 Puma 2.2 HT Corris Grey
That will be an engineered expansion gap. Thumbs Up Rolling with laughter You only have one life, live it....forget the cost.
90XS Hardtop
Post #225318 7th Apr 2013 9:35pm
BjornAgain
South Africa 1999 Defender 90 Td5 CSW Chawton White
There are two man made things that can be seen from outer space....
1. The Great Wall of China!
2. The gaps between the doors of a Land Rover!!!
Good luck!!!
Post #225321 7th Apr 2013 9:51pm
Natlas
I have gaps you could put your finger through at the front of both my 300 TDi doors, I regard them as drain holes for all the condensation or rain that pours down on to my legs/feet first thing in the morning as I brake at the bottom of the hill. Rolling with laughter
I will check the new one tomorrow though 2.2 90 XS
88" Series One
Old Norton Smile
Post #225323 7th Apr 2013 9:54pm
ClaireWright
United Kingdom 2008 Defender 90 Puma 2.4 HT Keswick Green
I have new door seals and can see daylight
Post #225340 7th Apr 2013 11:57pm
jst
have you got vents in the roof above the back door? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #225351 8th Apr 2013 7:50am
DarrenJ
You'd think they would suds the door seal by now on an off road vehicle wouldn't you!
I'd imagine if you stopped at all in water it would be straight through the gap, atleast when I drove a work van into a little puddle a few years ago it took quite a while to fill up with water.............. Whistle
When did they start to fit the new type seals? Mine is a 2011 build.
Cheers Darren
Post #225363 8th Apr 2013 8:16am
BigWheels
Better to have drainage plugs for flooding. Also handy when you have to flush out..stuff.
To cut down draughts, inner door flaps. Can be made by cutting up old (or new cheap) car mats. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #225636 8th Apr 2013 11:55pm
Braydog
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
I've often looked at those door seal gaps and thought I should do something about it but really, why bother. Water rarely gets in and when it does, it is no more than the waterI transfer from by boots. I guess if I was too fussed about such things, I would be better off buying a Toyota or something just as bland. Sometimes It is better to ask for forgiveness, than to ask for permission.
Post #230385 25th Apr 2013 11:07am
ClaireWright
Sounds familiar...they let the water out ! Door seals we replaced
Post #230387 25th Apr 2013 11:17am
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Re: Door seal
Stop worrying..... It's the air conditioning system 2007 TD5 90 Hard Top
Post #232317 2nd May 2013 9:36pm
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Defenders haven't had "proper" air conditioning since the opening vents disappeared......(insert 3 Yorkshireman sketch here).... 1970 Series 2A 88"
Post #232324 2nd May 2013 9:51pm
