![]() | Home > Puma (Tdci) > Door seal |
| Delskinz Member Since: 18 May 2012 Location: North Devon Posts: 84
From the inside looking at the bottom left of all the doors I see a small section where I see light too.
| Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 463
I'll check mine tomorrow, too late to see daylight now! 2.2 90 XS
88" Series One Old Norton Modern Honda and Harley |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Yes pretty common on the old type door seals especially when the little self adhesive rubber blocks in the corners drop off. The newer type seals follow the door contours better. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| Sonarmender Member Since: 04 Apr 2013 Location: Guz Posts: 338
That will be an engineered expansion gap.
90XS Hardtop |
| BjornAgain Member Since: 29 Oct 2012 Location: Johannesburg, South Africa Posts: 22
There are two man made things that can be seen from outer space....
1. The Great Wall of China! 2. The gaps between the doors of a Land Rover!!! Good luck!!! |
I have gaps you could put your finger through at the front of both my 300 TDi doors, I regard them as drain holes for all the condensation or rain that pours down on to my legs/feet first thing in the morning as I brake at the bottom of the hill.
I will check the new one tomorrow though 2.2 90 XS 88" Series One Old Norton Modern Honda and Harley |
| ClaireWright Member Since: 12 Oct 2012 Location: Warwickshire Posts: 609
I have new door seals and can see daylight
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8486
have you got vents in the roof above the back door? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312
You'd think they would suds the door seal by now on an off road vehicle wouldn't you!
I'd imagine if you stopped at all in water it would be straight through the gap, atleast when I drove a work van into a little puddle a few years ago it took quite a while to fill up with water.............. When did they start to fit the new type seals? Mine is a 2011 build. Cheers Darren |
| BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405
Better to have drainage plugs for flooding. Also handy when you have to flush out..stuff.
To cut down draughts, inner door flaps. Can be made by cutting up old (or new cheap) car mats. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
| Braydog Member Since: 11 Apr 2012 Location: Melbourne Posts: 27
I've often looked at those door seal gaps and thought I should do something about it but really, why bother. Water rarely gets in and when it does, it is no more than the waterI transfer from by boots. I guess if I was too fussed about such things, I would be better off buying a Toyota or something just as bland. Sometimes It is better to ask for forgiveness, than to ask for permission.
Sounds familiar...they let the water out ! Door seals we replaced
| Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582
Stop worrying..... It's the air conditioning system 2007 TD5 90 Hard Top |
| lukev01 Member Since: 24 Mar 2012 Location: Bedfordshire Posts: 412
Defenders haven't had "proper" air conditioning since the opening vents disappeared......(insert 3 Yorkshireman sketch here).... 1970 Series 2A 88"
