![]() | Home > Stolen > Attempted theft from Bartley green birmingham 2:30 am friday |
| YeomanOfTheBar Member Since: 04 Nov 2012 Location: North Notts Posts: 210
Nice |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6018
You would have to for that, I can't see them being impressed! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
That OBD socket really appeals, even if they trash the motor, it's insured it'll cock up any of their computer kit
I guess you could also go for a OBD socket with a key operated switch to enable/disable it.? 1999 Defender TD5 110
| shazzy90 Member Since: 17 Dec 2010 Location: tyneside Posts: 489 |
worring times
| chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559
this is why i am applying for a shotgun license
| lukev01 Member Since: 24 Mar 2012 Location: Bedfordshire Posts: 412
Was in a dealership today and noticed a leaflet on LR tracking device.
Does anyone have one? Are they any good? Worth the money? Will probably be buying a 110 in Sept so definitely want to keep hold of it once I (finally) can have one! 1970 Series 2A 88" |
| Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468
I have the Landrover Rac trackstar , much the same as all the rest. For my insurance, had to have approved tracker .
Sky tag seems ok and a good price. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
I have NEVER said it cannot be overcome, and once you have figured out how to do it the first time it is easy enough. |
| yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
I've had one pinched, then i bought a second 110, love it to bits, but if this goes i WON'T be getting another! life's too short.
| SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 674
No worries, you obviously know different now. When I responded before, you said you'd hadn't heard a case of a PUMA being stolen with a BBU fitted, obviously different now, so that's ok. Cheers Steve |
True, at that time I hadn't heard of one with a BBS fitted being stolen, which isn't quite the same as saying it can't be done. As we all know only too well now, it can be done but it requires more know-how, more equipment, and perhaps more importantly more time that one without.
Whereas at one time I would have thought a BBS was sufficient deterrent, the level of knowledge in the scumbag fraternity is clearly increasing as is sadly inevitable. It also doesn't help when programs like Countryfile teach everyone how to steal bonnets and programs like the scrapyard one mentioned in another thread remind all and sundry how easy and lucrative it is to break one for parts. I think now the best deterrent is to add as much security as you can live with and make the vehicle as non-standard as possible. Put an armoured cover over the 10AS unit, move the socket somewhere unexpected and use s non-standard connector (easy enough to make an adaptor cable for diagnostic gear, but don't leave it in the car), and wire up a nasty surprise on the original socket. Fit a self-contained alarm with a siren of at least 140dBm in an armoured box in the cabin, which will make it impossible to stay inside if it goes off. Fit two trackers, because when they find the first they will probably stop lookin. Fit the armoured sleeve on the lock barrel. Do the mod to the battery wiring to eliminate that well-known vulnerability. If you are really worried, dent or damage your doors, bonnet and other panels to reduce their resale value. Fit security hinges, move all sirens and sounders to unexpected and inaccessible places. If parked at home, run a lead to a house alarm that will sound if disconnected (shame if they hurt themselves tampering with this one). |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
The quote below is from another 'security related' thread. I am a strong believer that the 'layered approach' to theft prevention is the best solution. In your case this approach probably saved you the loss of the vehicle totally.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
Hi Mark
See your selling defender stuff did you manage to get insurance to sort it all out fairly & guessing the defender has now gone really sorry to see that good luck in your new choice of transport |
