Home > Stolen > Attempted theft from Bartley green birmingham 2:30 am friday
Page 2 of 3 <123>
excossack
Sorry to hear/read about the bad news.
It appears that they do the following (maybe in this order)
Removed indicator bulbs (no flashing from the alarm)
Remove the horns (no noise)
Get in and remove interior lights (no cabin light)
Now in darkness
Undo the handbrake, (maybe from underneath?)
Then onto the OBD socket to disable the immobiliser assuming they might use a laptop/other hand held device.?
Trash the barrel and drive off/move the car down the road. or in this case remove what they can and leg it. but have a van on standby to haul away the doors.
So, to make it harder & slow them down
Change the screws in the indicators to non standard ones
Fix and additional or alter the standard interior light so it uses non standard bulbs
Move the horns further back or add an additional horn not accessible as easy
Move the original OBD socket or add an additional one in the correct place and make it 12v live through all pins Smile
Change the door bolts again to non standard ones
Fit an additional separate alarm system with additional door pins/bonnet pins and a loop of wire through the bonnet so when its cut it also triggers the alarm.
Just some random thoughts. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #224839 5th Apr 2013 1:12pm
YeomanOfTheBar
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Santorini Black
Nice Twisted Evil. Just remember to tell the garage when you take it in for service Whistle 2013 Defender 110 XS DCPU
Post #224872 5th Apr 2013 3:45pm
excossack
You would have to for that, I can't see them being impressed! 1999 Defender TD5 110
Regards
John M0VAZ
Post #224873 5th Apr 2013 3:49pm
JWL
That OBD socket really appeals, even if they trash the motor, it's insured it'll cock up any of their computer kit Thumbs Up
Post #224874 5th Apr 2013 3:53pm
excossack
I guess you could also go for a OBD socket with a key operated switch to enable/disable it.? 1999 Defender TD5 110
Regards
John M0VAZ
Post #224875 5th Apr 2013 4:06pm
shazzy90
worring times
Post #224937 5th Apr 2013 7:58pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
this is why i am applying for a shotgun license Laughing
Post #224950 5th Apr 2013 8:35pm
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Was in a dealership today and noticed a leaflet on LR tracking device.
Does anyone have one? Are they any good? Worth the money?
Will probably be buying a 110 in Sept so definitely want to keep hold of it once I (finally) can have one! 1970 Series 2A 88"
Post #224951 5th Apr 2013 8:39pm
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
I have the Landrover Rac trackstar , much the same as all the rest. For my insurance, had to have approved tracker .
Sky tag seems ok and a good price.
Post #224957 5th Apr 2013 8:55pm
SteveG wrote:
Sorry to hear that, especially after you had gone to such lengths to protect it.
T1G UP wrote:
yep, there getting wise to the security if there accessing the OBD port.
Hardly surprising. It doesn't take a rocket scientist to work out that if you don't want an alarm to go off you disable the horns (Including the BBU that Blackwolf is convinced can't be overcome) and then reprogram a key and fob to car.
By the way, I had thought that fitting a hidden switch to the fuse circuit to the fuel pump would stop the engine from starting, but I found out on my 90 that its still possible to start with fuel pump fuse removed and drive off, albeit in limp home mode.
I have NEVER said it cannot be overcome, and once you have figured out how to do it the first time it is easy enough.
Post #224999 5th Apr 2013 11:10pm
yostumpy
I've had one pinched, then i bought a second 110, love it to bits, but if this goes i WON'T be getting another! life's too short. Whistle
Post #225092 6th Apr 2013 6:12pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
No worries, you obviously know different now. When I responded before, you said you'd hadn't heard a case of a PUMA being stolen with a BBU fitted, obviously different now, so that's ok.
Steve Smile
Post #225095 6th Apr 2013 6:36pm
True, at that time I hadn't heard of one with a BBS fitted being stolen, which isn't quite the same as saying it can't be done. As we all know only too well now, it can be done but it requires more know-how, more equipment, and perhaps more importantly more time that one without.
Whereas at one time I would have thought a BBS was sufficient deterrent, the level of knowledge in the scumbag fraternity is clearly increasing as is sadly inevitable. It also doesn't help when programs like Countryfile teach everyone how to steal bonnets and programs like the scrapyard one mentioned in another thread remind all and sundry how easy and lucrative it is to break one for parts.
I think now the best deterrent is to add as much security as you can live with and make the vehicle as non-standard as possible. Put an armoured cover over the 10AS unit, move the socket somewhere unexpected and use s non-standard connector (easy enough to make an adaptor cable for diagnostic gear, but don't leave it in the car), and wire up a nasty surprise on the original socket. Fit a self-contained alarm with a siren of at least 140dBm in an armoured box in the cabin, which will make it impossible to stay inside if it goes off. Fit two trackers, because when they find the first they will probably stop lookin. Fit the armoured sleeve on the lock barrel. Do the mod to the battery wiring to eliminate that well-known vulnerability. If you are really worried, dent or damage your doors, bonnet and other panels to reduce their resale value. Fit security hinges, move all sirens and sounders to unexpected and inaccessible places. If parked at home, run a lead to a house alarm that will sound if disconnected (shame if they hurt themselves tampering with this one).
Post #225114 6th Apr 2013 7:57pm
K9F
The quote below is from another 'security related' thread. I am a strong believer that the 'layered approach' to theft prevention is the best solution. In your case this approach probably saved you the loss of the vehicle totally.
K9F wrote:
It certainly surprised me.... Shocked
This is from another website and I think the 'ethos' behind the 'layered approach' is possibly the best way and is the one I myself have adopted, needn't cost a packet either..for example applying resin/ball bearings to torx screws etc....
Thumbs Up Thumbs Up
It is clear that there is no single magic solution to security. Each security product just buys you time - and it is time that is the real deterrent to potential thieves, not loud alarms nor flashing lights. Most people simply ignore alarms. The more time your vehicle takes to steal, the greater the chance a potential thief will be caught so the more likely they are to move on to a less protected vehicle.
Curiously, the magic time delay is roughly 2 minutes. A delay of 2 mins will make most thieves move to another vehicle. A delay of 4 mins will not give you twice the protection (a case of diminishing returns). However, two security products which each take more than 2 minutes to defeat does seem to offer double the protection. This is the reason specialists recommend a 'layered' approach. Each product provides one layer of protection and you decide how many layers you need for the risk in your area.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #225125 6th Apr 2013 8:31pm
pjb
Hi Mark
See your selling defender stuff did you manage to get insurance to sort it all out fairly & guessing the defender has now gone
really sorry to see that Sad
good luck in your new choice of transport Thumbs Up 2020 P300 HSE
Post #249967 8th Jul 2013 2:41pm
Page 2 of 3 <123>
