![]() | Home > Technical > Mud Rails |
| mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109
Not in your area but I am 6'4" and have them fitted and its fine Kevin from mud is 6'5"
| bcp Member Since: 01 Aug 2012 Location: East of Scotland Posts: 94
Great to hear, was a bit worried I'd be too high.
| bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189
one of the best mods in my humble opinion. BM52
| ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831
I might be on the wrong track, If you mean the steel wedges that are fitted to allow the seat to slide further back I have words of caution.
I had a set fitted when I took delivery of a 110 in December last year as I felt that the seat was to far forward, I'm only 5' 10". a) The seat belt was not over the shoulder as required by law but cut across the upper arm making it even more difficult to steer. b) I had to duck down to allow me to see out of the drivers side window when looking out . I have now taken them out and they sit on top of the cupboard in the garage awaiting disposal. |
| Peter Evans Member Since: 20 Apr 2012 Location: west wales Posts: 7
i am 6"3 i fitted them the are good only problem is i have to lower my head to see out of the side window a little now got used to it no problem ahead though
I agree with Peter Evans but that is a small price to pay for comfort. I wouldn't be without them now. BM52
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
| SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491
the avitar was a bond thing can change to another
| WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748
Im 6'3 and dont have mud rails in my 110 300tdi as I really dont need them at all. I smaller steering wheel is essential for me though as otherwise I can't lift my leg when operating the pedals.
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
The quick fix option is to pack washers under the rear 2 bolts so that the seat rail is not obstructed
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
I don't mind sharing Miss Moneypenny.....
| Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767
I had them fitted for about a year but removed & sold them a couple of months ago.
They were fine comfort wise but I got fed up ducking down to have a good look out of the window. Make sure to try a set first and be certain you can live with them. ONE LIFE, GET IT! |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
It's a matter of taste, I suppose. I'm 5'11" and I wouldn't be without them because
a) I like being higher up and further back (I was actually in pain without them and some seat supports) b) the seat belt is just brushing my shoulder (rrrrrrrr) c) they give my arms just the right height to rest on the window frame and cubby (with under-cubby box) at the same time. I don't care that I have to duck down a bit to see the traffic lights - at least I can look down at the eurobox next door But shout it at them in German because life is also terrifying and confusing... |
