![]() | Home > Technical > Mud Rails |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 ![]() ![]() ![]() |
I'm 5'10" and have relatively short legs an whilst the actual seat position was ok getting in and out was a bind with the rails in, partly due to the full sized steering wheel and partly due to the height of the base above the ground. So i got rid. Rhubarb and custard let fly with their secret weapon.
You've a good point there - if I didn't have a smaller steering wheel it probably would be a PITA
![]() But shout it at them in German because life is also terrifying and confusing... |
bcp Member Since: 01 Aug 2012 Location: East of Scotland Posts: 94 ![]() ![]() |
Currently a toss up between D4 commercial and 110 utility. Heart says 110, brain says D4....
They were fitted in the FCX 130 by the PO and I really couldn't get on with them, changes the distance between your arm and cubby, steering wheel etc etc.
However if you buy a set and then don't like them you can always sell them on at very little loss financially. In all honesty the height of your seats is not your biggest problem when choosing between a 110 USW and a D4 ![]() |
