![]() | Home > For Sale & Wanted > Wanted: 90 or 110 Utility Sides (no side or rear windows) |
| SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455
I found it impossible to find any - they are £400/side from LR. All the breakers have received weekly phone calls from me for 6 months without result.
I have ended up buying 90 sides and shortening them. There are some spot welds to remove - the panels have corner strengthening brackets on the front edges. When these are off, it is a 10 minute job at your local engineering firm (and a £20 note) to have the folds replicated. Overall length needs to be 1315mm. Then, the corner brackets need reattaching (I plan to bond mine in place) and a few holes enlarged or created on the roof side to allow the bolted joint to work. Lastly, a visit to the spray paint man (cost unknown at the moment!) before the job is done. This will mean that you have rear quarter windows - but I dislike the blank panels when viewed from behind.
Untitled by Scgwhite, on Flickr My blog - www.anacreinhampshire.blogspot.co.uk 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
thanks Simon, great idea.... anyone got any 90 or 110 sides ?
| Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 |
Contact Equicar 4x4. I bought some take-off 110 sides from them and had them shortened by the bodyshop before the sprayed them. Note that if using 110 3 door sides the vertical strengthening pieces are spaced differently so when sides are shortened TGE type trims won't fit. As I found out
| appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630
How about 88" panels? They do fit.
They do fit, but have domed rivets all over them. Not fitting on a modern vehicle IME. My blog - www.anacreinhampshire.blogspot.co.uk
| SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 675
Hi Si
Glad they were of use. Wasn't sure if you'd use them, as they had been well used/abused. Cheers Steve |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Yeah, but what about Defenders? 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Drill out and re rivet? |
I'd drill out the domed rivets and spot weld them. By the time you've done that, might just be easier to shorten the 90 panels... My blog - www.anacreinhampshire.blogspot.co.uk
Champion Steve - there are a few lumps and bumps which the body shop can sort when they get painted. Even brand new vehicles don't have straight USW panels... Very grateful for them old fellow... My blog - www.anacreinhampshire.blogspot.co.uk 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
| udderlyoffroad Member Since: 18 Jul 2011 Location: Bristol Posts: 124
Ohh another USW build Si?
I tracked down a pair of 88 van sides for peanuts (and indeed you generously offered me your spare set) - they do indeed have domed rivets and rear quarterlights. Hopefully the former will be less obvious on my 'old skool' paint job (Massey Ferguson red). As for the latter, I personally prefer the USW 'blank' look but will be fitting dark tinting film. What colour did you go for Si? Righto, time to put brew and laptop down and get outside spannering. Real trucks don't have spark plugs |
