Home > For Sale & Wanted > Wanted: 90 or 110 Utility Sides (no side or rear windows)
as heading, after a pair of utility sides for a 110, colour does not matter probably going to wrap
Post #219314 15th Mar 2013 6:29pm
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
I found it impossible to find any - they are £400/side from LR. All the breakers have received weekly phone calls from me for 6 months without result.
I have ended up buying 90 sides and shortening them. There are some spot welds to remove - the panels have corner strengthening brackets on the front edges. When these are off, it is a 10 minute job at your local engineering firm (and a £20 note) to have the folds replicated. Overall length needs to be 1315mm. Then, the corner brackets need reattaching (I plan to bond mine in place) and a few holes enlarged or created on the roof side to allow the bolted joint to work. Lastly, a visit to the spray paint man (cost unknown at the moment!) before the job is done.
This will mean that you have rear quarter windows - but I dislike the blank panels when viewed from behind.
Untitled by Scgwhite, on Flickr My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #219328 15th Mar 2013 7:39pm
thanks Simon, great idea.... anyone got any 90 or 110 sides ?
Post #219338 15th Mar 2013 7:51pm
Romadog
Contact Equicar 4x4. I bought some take-off 110 sides from them and had them shortened by the bodyshop before the sprayed them. Note that if using 110 3 door sides the vertical strengthening pieces are spaced differently so when sides are shortened TGE type trims won't fit. As I found out Mad
Post #219343 15th Mar 2013 8:06pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
How about 88" panels? They do fit.
Post #219442 16th Mar 2013 12:07am
SiWhite
They do fit, but have domed rivets all over them. Not fitting on a modern vehicle IME. My blog - www.anacreinhampshire.blogspot.co.uk
Post #219443 16th Mar 2013 12:20am
SteveG
2005 Defender 90 Td5 CSW Belize Green
Hi Si
Glad they were of use. Wasn't sure if you'd use them, as they had been well used/abused. Wink
Steve
Post #219444 16th Mar 2013 12:24am
Yeah, but what about Defenders? Laughing Darren
Post #219454 16th Mar 2013 1:23am
appaloosadude
Drill out and re rivet?
Post #219455 16th Mar 2013 2:28am
SiWhite
I'd drill out the domed rivets and spot weld them. By the time you've done that, might just be easier to shorten the 90 panels... My blog - www.anacreinhampshire.blogspot.co.uk
Post #219469 16th Mar 2013 9:18am
SiWhite
SteveG wrote:
Hi Si
Steve
Champion Steve - there are a few lumps and bumps which the body shop can sort when they get painted. Even brand new vehicles don't have straight USW panels... Rolling Eyes
Very grateful for them old fellow... My blog - www.anacreinhampshire.blogspot.co.uk
Post #219470 16th Mar 2013 9:20am
udderlyoffroad
Ohh another USW build Si?
I tracked down a pair of 88 van sides for peanuts (and indeed you generously offered me your spare set) - they do indeed have domed rivets and rear quarterlights. Hopefully the former will be less obvious on my 'old skool' paint job (Massey Ferguson red).
As for the latter, I personally prefer the USW 'blank' look but will be fitting dark tinting film.
What colour did you go for Si?
Righto, time to put brew and laptop down and get outside spannering. Real trucks don't have spark plugs
Post #219478 16th Mar 2013 10:09am
