Page 462 of 1393 <123 ... 461462463 ... 139113921393>
PK1
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Picked my 110 up today from being waxoyled - local garage did an excellent job. Smile Defender 110 TDCi XS SW
Range Rover Sport HSE
Post #217294 8th Mar 2013 10:25pm
excossack
Car packed, Harvey frost hooked up and ready to roll for tomorrows trip to Blyton. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #217491 9th Mar 2013 6:51pm
JWL
Seeing as it had stopped raining in the afternoon(Saturday) I got round to replacing the front pipe on my Td5. This is now the third in 12 months Shocked Bit of a pita but all replaced under warranty from the motor factors(next door neighbours place of employment), they've all snapped the swaged flange where the front pipe meets the middle pipe. It's annoying in the fact that there is nothing obvious in causing it to break apart from perhaps the quality of the parts which are made by Klarius, supposedly the fastest growing manufacturer of OE quality replacement automotive parts in Europe. Hmm, we shall see how long this one lasts, one thing about it, I have got the change down to 20 minutes with removing and replacing the centre crossmember Wink
Post #217612 10th Mar 2013 1:31am
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Replaced the rear brake pads on the 110.
As is always the way, I discovered a very stiff piston and a popped seal. I tried to fit a new seal but gave up in the end.
Time for a new calliper!
Post #217657 10th Mar 2013 9:41am
mk1collector
Fitted the new rear speaker trims Mr. Green and found and stopped the dammed gear lever rattle Whistle
Post #217662 10th Mar 2013 9:55am
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
Had a Stage 2 remap done by Big Steve Thumbs Up great service & picked up a VNT turbo & boost box for a mate. While the remap was being done I got a trip in The 3.2!!!!!!! Shocked It is brilliant, sounds like a proper Land Rover and has power everywhere just no roads long enough.
Post #217676 10th Mar 2013 10:15am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Thanks yobbie glad to be of service here to help Thumbs Up
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #217691 10th Mar 2013 10:34am
Offroad-Tec
Germany
Rock Slider 110 HCPU
Yesterday we fitted our new rock sliders for the Defender 110 HCPU. The look very fine, ready constructed brackets, without drilling and damming under the car Smile. The Body isn't modificated, it's plug & play!!!
Now they get a hot-dip galvanized zinc coating, than a professional powder coating in black.
Markus
[/img]
Post #217703 10th Mar 2013 10:51am
My 110 was pressed into service as a furniture van (again!) for a trip to that cathedral of domestic servitude that is Ikea Sad
Also decided to fill up with BP Ultimate to see if it lives up to the hype. My wallet is still hurting from the experience but I'll persevere for a couple of tankfuls before deciding. Darren
Post #217912 10th Mar 2013 10:33pm
macduff
Toboggan run
Decended a road into the village on full right lock broadside Shocked .
We've had a bit of snow overnight and came back from filling up via local back road. It looked a bit iffy from the failed climb tyre marks in the snow, so selected 1st low (no diff lock) and let it crawl down but still ended up in a slow slide down with TC chattering away. Light brush with the hedge and some grip was given by the undergrowth gave it enough to straighten up. Must get some better road/snow tyres than the BFG MTs.. 2023 110 P400e
Post #217994 11th Mar 2013 1:08pm
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
Mine way more prosaic than sliding down a slope! Shocked
Just spend a bit (too much) of time taking door card off so I could re-attach the door handle that had partly come off! ...
Post #218006 11th Mar 2013 1:39pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
@macduff
Out of interest why did'nt you engage diff lock. I think I would have had it engaged - or am I missing something? Going up I would have it engaged, is there a difference going down a slippery slope?
Cheers BM52
Post #218010 11th Mar 2013 1:47pm
macduff
I was in two minds on diff lock as it had appeared to be a hindrance recently on a climb in similar snow conditions, when both ends were on the limit of traction I found if one wheel spun the diff lock transfered the rise in transmission speed to the other end which also lost grip and ended up crabbing to a degree that needed it digging out to get grip back (it was on a hill with side slope that is my access lane leading to drive) . I'm not that keen on testing it just at the mo but given the result without difflock I'll probably have it in for the next decent that has a similar conditions (of slippery snow/ice) . Ps just been to the LR experience at skipton where descents and climbs were a piece of cake with difflock low 1st though it was soo dry it was almost hard backed dusty and the instructor advised the MTs werent that good in snow and I should think about the Crosscontact ATs their cars had on as they had found they were pretty unstoppable (at the skipton site) as long as ground clearance was maintained. 2023 110 P400e
Post #218021 11th Mar 2013 2:30pm
Christian
Qatar 2008 Defender 90 Puma 2.4 SW Java Black
Will look forward installing what I just received...
...from a very good friend (I wonder where he found it !)
As it's blank I'm tempted to have it engraved with the truck's name Very Happy
...and from LR Series Thumbs Up Chris
Post #218035 11th Mar 2013 3:37pm
Defender-Stu
not in the Defender but i have had to just bbok mine in for its first visit back to the dealer for the recall on the boost pipe and for a hand full of other bits to be sorted Rolling Eyes
Post #218038 11th Mar 2013 3:50pm
