![]() | Home > Puma (Tdci) > Just a thought: Can I install an ABS-TC in a 08 MY Defender? |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Just that, and to do not hijack the previous post.
It is possible to install as a kit the ABS-TC package in a 08 MY without it? Some idea about the cost? Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 ![]() ![]() ![]() |
It's only electrical, no need for new axles
![]() ![]() Going with the defender normally, the wiring is also probably already there ![]() |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
I seem to recall someone investigating this before and it was prohibitively expensive. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
I don't think you will have wheel speed sensors on a none ABS vehicle. At least you don't have that on a none ABS TD5. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2489 ![]() ![]() ![]() |
just the modulator costs over 2000 quid Puma 110" SW
Just make silly noises, stamp on and off the brake and install a flashing led light, it's much cheaper and has the same effect.
![]() 110 HCPU Tipper |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
Not really the same effect! and you cant beat ABS/TC and you cant manually simulate it to the same efficiency or effectiveness. ![]() You will need from memory: Sensors Wiring ABS/TC ECU Different Hubs Different Brake disc's (maybe also callipers and pads i cant remember) Modulator Pipes Mike Last edited by mse on 9th Jan 2010 10:23am. Edited 1 time in total |
Oh ![]() ![]() |
Ed,it would prob cost less to swop your truck for a new one with ABS/TC. 2.4 90 XS
Why ABS?????
a real offroader work better WITHOUT!!!!! Try the abs when descent a snowy hill.....................and pray.............. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Ignoring the fact that Hill descent is based on ABS and off road advice in the handbook says the onlly abs equipped vehicles are recommended to brake on decent Before anyone says i know pic the speed avoid breaking is the best way. Mike |
Sorry, I prefer lsd diff not the brake if someoune want Hll descent, ABS, DSTC .... please chose a X5 or a Q5 have you never drove in a very icy steep reduction with abs.... TC is the best way to destroy shaft and diff Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
The best would be to have both options i.e. be able to choose when you want traction control, hill descent etc. Then turn them off when you don't. The Hill descent works great in our freelander 1 which doesn't have a low range box, can't stop but at least you can steer :rolllaugh hill descent was also usefull on the corpulent D3.
and you can't deny that traction control on the D3 is very good. ![]() ![]() 110 HCPU Tipper |
