![]() | Home > Puma (Tdci) > Weird Temperature issue |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
I bought one of the rugged guide winch and wade blankets
see here on ebay Does a pretty good job of keeping temperature up and getting up to temp faster. Has the added advantage of other uses too (although a bit more pricey than peanutbob's mat ![]() + New Defender 110 First Edition |
Fandango Member Since: 29 Jul 2009 Location: Jersey Posts: 21 ![]() ![]() |
Alantd, Looks good, how does it fit to the front? Does it involve drilling & screwing? I'm not sure I can bring myself to do that yet as it's only 3 months old!! ---------- 2021 D250 90 X-Dynamic HSE 2020 IPace - Gone 2015 RRS - Gone 2011 Disco 4 - long gone 2009 TDCi 90 CSW - long long gone |
No drilling. There are 4 screws on the leading edge of the bonnet that hold the slam plate. You just take them out (self tappers) and reattach them through the eyelets in the blanket collar. The main blanket then just velro's on and off. The only design flaw in my opinion is that I'm pretty sure that the collar would flat about a bit at speed so I tucked it back on itself, under the bonnet before I shut it. In doing so, one of the webbing attachments fouls the bonnet mechanism slightly and will get damaged over time with repeated opening and shutting. That said, I've not spent much time looking at a workaround so I'm sure it'll be easy to resolve. Good piece of kit I reckon. I just secure it to the grille with bungees (I don't have a winch or A-bar to tuck it behind). If you have front spots, you'd have to route the wiring through the bottom of the grille so as not to interfere with it. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
Just found a real world issue with this cooling problem.
I was out with the response team at the weekend - taking nurses on district rounds. They'd go into the houses to do their thing and I'd wait for them outside. Even with the engine running, the temperature of the engine quickly dropped and the heater output fell away. If they were more than about 20 minutes, I was left sat in a freezing cold Defender. Good to know that it wouldn't overheat sat still for a day, using the Power Take Off in the desert but I was freezing my nuts off after a few hours work ![]() Eberspacher, here I come! One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Ignoring for winching and water into engine benefits - im not sure if this blanket is going to solve the problem - personally i dont think its a cooling issue in the way blocking the radiator is going to solve...it would seem anyway. Mike
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
Efficient diesel engine I reckon
Just make sure you carry a warm woolly jumper
![]() ![]() 110 HCPU Tipper |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 813 ![]() ![]() ![]() |
I did same last week - engine off, puffer jacket on, & flask of hot coffee was the cheapskate solution for me! |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
The 300 Tdi and Td5 are the same problem in extreme cold weather. This is why the Army use radiator Muffs on all its winterised vehicles and if you go places like Canada, Falklands etc they all have Rad Muffs on during the winter months. The problem with the viscous fan is that it is always spinning therefore even though the thermostat has the water flow turned off to the radiator it is still blowing -15 DegC air along the engine block cooling it down. Glyn |
