![]() | Home > Maintenance & Modifications > Outside temperature gauge |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
Watching with interest. It's one of those 'gadgets'. Yet I always check it in the Audi and often wander when I'm in the 90.
Good post chipmunk |
| iPints Member Since: 15 Jun 2012 Location: SC Posts: 294
http://www.egauges.com/vdo_mult3.asp?Type=...mp;Units=M
Not sure about quality......but it's VDO so should be good. |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
Take a look at the Mobile Centre website
I've fitted one of their digital temperature read outs to the FCX 130, pictures on my 130 thread |
| Generaldej Member Since: 30 Dec 2012 Location: Milbury Heath Posts: 82
Got one of these from China http://www.ebay.co.uk/itm/120995824095?var...1497.l2649
Mine arrived in less than a week. I'm very very happy with it |
| chipmunk Member Since: 10 May 2012 Location: Kelso Posts: 264
Thank you all. Will research some. Cheers.
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327
Problem I've always had with the add-on sensors in any car I've tried them is not the quality of the gauge, it's not difficult to make a temp probe, but it's where to put it to be accurate.
Temp drops when driving and rises when stopped. Be interested to know where folks have placed their sensors. Manufacturers normally place them low down at the front of the car. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
OBDCII readers use the vehicles temperature sensor, a nanocom would work fine on a td5
| Kraut Member Since: 28 Dec 2011 Location: Westphalia Posts: 336
That's the one I got installed from the dealer instead of the oem clock, fits neat and looks better than the usual lcd-displays as it's looks as if it has allways been there Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
CheckTemp2 is popular on here...I've got one, works a treat!
http://www.defender2.net/forum/topic5492.html Click image to enlarge Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Yes Craig, was hoping to pick up some probe positioning info'. Needs to be in the open but out of airflow I suppose? Wind chill factor? Very useful tool in GF's Golf. VDO one seems very expensive but looks good. Would replace clock too.
| me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856
As far as I know taking the AIT from the ECU won't give an accurate impression of the outside air temp.
Behind the bumper would be good for the sensor but if it collects snow it will give a false low. |
| cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336
Mine's in the headlamp enclosure, seems to work well. |
Mine's set inside the drivers-side wing, near the headlight. When the car's sitting stationary in the sun it reads a bit high, but once moving it's spot-on.
On a previous car it was located in the air intake for the engine (somewhere in the airbox) - that worked really well...as soon as the engine is started it sits in a gentle flow of fresh air |
| Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514
I too ! ! http://www.politecnica80.it/checktemp.asp?login=undefined http://www.speedup.it/1131211/termometro-e...tecnica-80 http://nakatanenga-tours.de/shop/article_N...THERMDZ%26 Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
| All times are GMT |
