Home > Maintenance & Modifications > Turbo gasket sealant?
ZeDefender
Just about to re-fit my turbo to the exhaust manifold with a new Nakatanenga gasket. Does it make sense to use some kind of high-temperature sealant, or should I fit it dry and hope for the best?
Matt Tell someone you love them today because life is short.
Post #214179 25th Feb 2013 2:45pm
totalal
Wales 2001 Defender 110 Td5 DCPU Tonga Green
As long as your mating surfaces are clean and flat fitting dry should be fine.
Al 01 Defender 110 Crew cab TD5
07 Discovery 3 TDV6 XS
Post #214356 25th Feb 2013 10:21pm
ZeDefender
Cheers Smile
It's the "flat" I'm not entirely sure about but I don't want the hassle of taking everything off to skim yet. That's why I wondered if I could "cheat" a bit. Oh well, I'll try with (yet) another gasket and see.
Post #214385 26th Feb 2013 7:18am
BruceT
South Africa
We have a product which works very well called Firegum in South Africa. I dont know if you have it in Europe. "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #214434 26th Feb 2013 1:12pm
ZeDefender
Thanks -
http://www.ebay.co.uk/itm/SPA-Turbo-Gasket...27bf564282
- similar to Firegum?
Matt
*edit* just realised the loctite doesn't go hot enough Rolling Eyes Tell someone you love them today because life is short.
Post #214481 26th Feb 2013 3:50pm
BruceT
South Africa
Here you go:
http://reviews.halfords.com/4028/741520/reviews.htm "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
Post #214684 27th Feb 2013 5:36am
ZeDefender
Cheers - bought some off Fleabay - I'll just smear a thin layer on both sides of the copper gasket to fill small leaks Thumbs Up
Post #214815 27th Feb 2013 7:03pm
ZeDefender
*Update*
Well, sadly the Firegum didn't work either, so I have to assume one (or both) manifold mating surfaces is warped Evil or Very Mad
So eventually I did something radical...
The Nakatanenga gaskets arrive with a rough surface (not sure of the reason), so I sanded down the manifold surfaces by hand until they were absolutely smooth (using a vacuum cleaner to remove dust afterwards) and also the gasket until it was shiny. Then I filed down the corners a bit, until there was a ring of thicker material left around the hole. This way, when the bolts were tightened at the corners, there was more pressure around the centre. After a few long trips, and re-tightening the bolts whilst hot, it doesn't seem to leak any more - fingers crossed Confused
Thanks to all for advice. Tell someone you love them today because life is short.
Post #227702 16th Apr 2013 5:48am
