Home > Td5 > Bulb replacement on land rover fitted spotlamps on A softbar
Pete Kettell
United Kingdom 2004 Defender 90 Td5 HT Epsom Green
Apologies if this is out there, but I cant find if this has been addressed before, but I have a TD5 fitted with a factory fit soft A bar with Land Rover spots that are wired into the full beam. My daft question is how do you get inside them to change the bulbs? There appears to be 2 screws on the back and the clamp that holds the spot and sets the beam pattern. rather than muck up the alignment I just thought I'd ask for the wisdom of the forum, as somebody must have done this before. Thanks in advance.
Post #214433 26th Feb 2013 2:11pm
landy andy
Think there is a small screw on the very bottom of the bowl. Then they may need a bit of twisting, prying, to separate the two parts at the bottom and then unhook the tops.
Andy
Post #214591 26th Feb 2013 9:21pm
TooTall
United Kingdom 2004 Defender 90 Td5 HT Tonga Green
^^ What he said ^^
I had the same problem but can I also suggest that before you rebuild the spots; you weatherproof them with some black B&Q bathroom silicon sealant... "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows."
Post #214623 26th Feb 2013 10:13pm
Pete Kettell
Thanks Landy Andy, but there is no small screw on the bottom. It appears that they only way to get at the back screws is to undo the clamps and rotate them taking them out of alignment. A small problem, but if I didnt have to use that option I wouldn't . Maybe thats the way to go if no better options appear. Weatherproofing them seems a good idea Too tall. Thanks for your input Currently on my fifth Defender. Had bespoke soft top and a 300TDI I bought twice and two TD5's. Currently driving the best second hand 2004 TD5 in the country
Post #214717 27th Feb 2013 12:33pm
mk1collector
You might be best putting up a pic of the lights so we can give you a definitive answer.
Post #214721 27th Feb 2013 1:04pm
Pete Kettell
Blimey, I've just spent ages trying to work out how to post a pic on the Forum. I think the time would be better spent on working out how to remove the headlamp bulbs. LOL Currently on my fifth Defender. Had bespoke soft top and a 300TDI I bought twice and two TD5's. Currently driving the best second hand 2004 TD5 in the country
Post #214735 27th Feb 2013 3:33pm
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
Post #214737 27th Feb 2013 3:38pm
Pete Kettell
Thanks for the tip. I have now successfully loaded a pic of the lights into my gallery, but I dont know how any of you would view it, but its there if you know how. Thanks everyone Currently on my fifth Defender. Had bespoke soft top and a 300TDI I bought twice and two TD5's. Currently driving the best second hand 2004 TD5 in the country
Post #214767 27th Feb 2013 5:43pm
Pete Kettell
Jes its easy, just click on gallery! Currently on my fifth Defender. Had bespoke soft top and a 300TDI I bought twice and two TD5's. Currently driving the best second hand 2004 TD5 in the country
Post #214769 27th Feb 2013 5:44pm
TR51
There you go, sorry they're not the style I know how to strip down...
Post #214802 27th Feb 2013 7:31pm
mk1collector
Ok, it will be easiest to unbolt the light off the a bar at the top as there are three posidrive screws to undo on the back of the light then the bulb just unclips out.
Hope this helps
Ray
Post #214818 27th Feb 2013 8:06pm
mk1collector
You may be able to loosen the bolt that holds the light on the a bar and just spin the light around instead of taking it off completely but be careful you don't break the wires Thumbs Up
Post #214820 27th Feb 2013 8:09pm
Pete Kettell
Thanks Guys, had to swing them round in the end. Currently on my fifth Defender. Had bespoke soft top and a 300TDI I bought twice and two TD5's. Currently driving the best second hand 2004 TD5 in the country
Post #216070 4th Mar 2013 3:00pm
Pete Kettell
Post #216071 4th Mar 2013 3:00pm
