Home > Td5 > Td5 original horn set up
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
When I acquired my second hand 2005 Td5, the horn set up was best described as 'wired for two, fitted with one'.
Was the typical set up on Td5s when they left the factory? Jon - 110 td5 [sold]. Currently Defenderless.
Post #213007 21st Feb 2013 7:31pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Mine has one horn on the nearside. Not found the wiring for the second, but haven't looked very hard.
Post #213020 21st Feb 2013 8:31pm
bob neville
2001 90, horn on nearside and wiring on the offside.
2013 Defender 90 CSW - sold
Post #213022 21st Feb 2013 8:36pm
appaloosadude
Cool. I might look for the plug on mine then.
Post #213023 21st Feb 2013 8:40pm
I replaced mine with a nautilus. Which only works with the alarm. So I think, horn one side, alarm horn the other?
Post #213025 21st Feb 2013 8:47pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
My 2005 xs has them on both sides and both sound when horn is pressed, maybe it's an option
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #213045 21st Feb 2013 9:23pm
Think it was an option to have a "high tone" and a "low tone" together, should be plug & play
Post #213049 21st Feb 2013 9:34pm
party monkey
Thanks chaps. I fitted a second horn a while back and indeed it was simply plug and play. Both now sound when the horn is pressed and indeed when triggered by the factory alarm. In fact the second horn works perfectly independently in both scenarios too.
So it sounds like unless the high/low option was specified the Td5's would have left the factory with just a single horn. Sure you can see where I'm going with this. Jon - 110 td5 [sold]. Currently Defenderless.
Post #213074 21st Feb 2013 10:23pm
3 Lions
Australia 2006 Defender 110 Td5 SW Chawton White
Re: Td5 original horn set up
Mine's a Nov 2006 build, It had one horn in N/S wing and wiring in other side but no Horn.
I fitted a Stebel Nautilus Truck Air Horn Twisted Evil on this side.
If I give the horn a quick jab you get the one horn, but if you press the Horn for more than a nano second you get the truck horn as well.
This is reserved for Censored who pull out in front of me or cut me up Twisted Evil
Col. 1979 Series 3 109 FFR (ex Aust Army.)
2006 Defender TD5 110.
2012 Trackabout CT.
Post #213210 22nd Feb 2013 1:02pm
Laurie
Will
Must be. Mine only came with one.
Post #213211 22nd Feb 2013 1:09pm
Romadog
My 110 is using 50th loom which has two connections. I have fitted one horn and bracketry from Td5, but am struggling to find the bracket for the other side. Its an angle bracket which is hannded. Dealer has struggled to find part number for me. I have given up for now.....but if anyone knows more ?
Post #213337 22nd Feb 2013 7:09pm
party monkey
Best guess chap is that you want the following.....
RH - ASU710060
LH - ASU710070
I got the part number info on the interweb somewhere, so I ordered both from Duckworths a couple of months ago (2.20+VAT each at the time), given that for a couple of quid each, it was easier to order both than end up with the wrong one from a bum steer
Piccy of both if that helps confirm they look like what you need ??
I just need to get around to making a proper job of fixing the new horn as currently, I'm using a horn+bracket from a scrapped Rover 75. Works perfectly but the rover bracket orientation is wrong and that just annoys me Jon - 110 td5 [sold]. Currently Defenderless.
Post #213480 23rd Feb 2013 12:47am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
Mine is farmer spec and it came with two. So it's the luck of the draw, I guess. The defender has migrated, leaving the owner behind.
Post #216035 4th Mar 2013 12:08pm
Romadog
Thank you Party Monkey Thumbs Up
Post #216129 4th Mar 2013 6:59pm
