![]() | Home > Td5 > Td5 original horn set up |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 ![]() ![]() ![]() |
Mine has one horn on the nearside. Not found the wiring for the second, but haven't looked very hard.
2001 90, horn on nearside and wiring on the offside.
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Cool. I might look for the plug on mine then.
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
I replaced mine with a nautilus. Which only works with the alarm. So I think, horn one side, alarm horn the other?
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
My 2005 xs has them on both sides and both sound when horn is pressed, maybe it's an option
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
Think it was an option to have a "high tone" and a "low tone" together, should be plug & play
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
Thanks chaps. I fitted a second horn a while back and indeed it was simply plug and play. Both now sound when the horn is pressed and indeed when triggered by the factory alarm. In fact the second horn works perfectly independently in both scenarios too.
So it sounds like unless the high/low option was specified the Td5's would have left the factory with just a single horn. Sure you can see where I'm going with this. Jon - 110 td5 [sold]. Currently Defenderless. |
3 Lions Member Since: 11 Jun 2011 Location: Geelong, Victoria Posts: 44 ![]() ![]() ![]() |
Mine's a Nov 2006 build, It had one horn in N/S wing and wiring in other side but no Horn. I fitted a Stebel Nautilus Truck Air Horn ![]() If I give the horn a quick jab you get the one horn, but if you press the Horn for more than a nano second you get the truck horn as well. This is reserved for ![]() ![]() Col. 1979 Series 3 109 FFR (ex Aust Army.) 2006 Defender TD5 110. 2012 Trackabout CT. |
Must be. Mine only came with one. ![]() |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
My 110 is using 50th loom which has two connections. I have fitted one horn and bracketry from Td5, but am struggling to find the bracket for the other side. Its an angle bracket which is hannded. Dealer has struggled to find part number for me. I have given up for now.....but if anyone knows more ?
Best guess chap is that you want the following..... RH - ASU710060 LH - ASU710070 I got the part number info on the interweb somewhere, so I ordered both from Duckworths a couple of months ago (2.20+VAT each at the time), given that for a couple of quid each, it was easier to order both than end up with the wrong one from a bum steer Piccy of both if that helps confirm they look like what you need ?? ![]() I just need to get around to making a proper job of fixing the new horn as currently, I'm using a horn+bracket from a scrapped Rover 75. Works perfectly but the rover bracket orientation is wrong and that just annoys me Jon - 110 td5 [sold]. Currently Defenderless. |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
Mine is farmer spec and it came with two. So it's the luck of the draw, I guess. The defender has migrated, leaving the owner behind.
Thank you Party Monkey
