![]() | Home > Technical > Free play in back axle ? |
Generally folks reckon that anything up to 1/4 turn of free play at the rear wheel is "ok", especially on salisbury axles.
It is most likely that the free play is in the splines of the hub to half shaft and can be improved by replacing the hubs at very little cost and effort. If you want better then you can also replace the half shafts as well. |
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 ![]() |
I reckon it's probably about 1/8 of a turn, or maybe a little more, might pull out half shafts tomorrow and have a look.
Is this more likely than play in crown wheel and pinion then ? Is there anything to check on the front axle ? |
When looking to diagnose transmission issues I find it helpful to start with the weak link, in the case of axle play it is nearly always wear in the hub and half shaft splines. If you chock your front wheels, jack up a rear wheel, pop off the little rubber hub cap and whilst slowly turning the wheel look at the mating of the splines if there is a lot of wheel movement of the wheel before the splines lock up then look to replace the hub. LR designed the hubs to be the weak link as they are cheap and dead easy to replace, anywhere, problem with that is that they wear over time... So it is unlikely to be the crown wheel. Usually when the crown wheel is worn or not set up correctly it whines like a banshee. |
Cheers for the info, will try that out tomorrow.
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1861 ![]() ![]() ![]() |
I have had the rear end 'clunk' reappear, have swapped drive flanges twice before, but now thinking the shafts are worn as well - just bough a set of these:
http://www.ebay.co.uk/itm/221185931905?ssP...1497.l2649 Bargain! Keith |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8461 ![]() ![]() ![]() |
as above most likely to be drive member issue, if i was changing these i would prob do the shaft too.
wear on the pinion/crown wheel is unlikely - does it howl? 1/8th turn i would of thought would be ok Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
No howling, the problem I'm having is controlling it in slow moving traffic, I get a kind of surging or jumping in the drivetrain.
If i accelerate it goes away. |
Hi Keith. Other reasons for a rear end clunk are; 1) A-frame ball joint - said to be the main clunk, but rarely actually the problem 2) Mal-fitting brake pads - more common than you think, clunk beautifully and can also rattle too. 3) Trailing arm bolts - These do wear over time where they contact with the axle mounts which is why if you change the bushes it is a good idea whilst you are there to spend the extra couple of £s replacing the bolts and nuts (grease them up good and proper too) 4) Hubs - as said earlier 5) Propshaft UJ - These need greasing regularly and can go PDQ especially if you have a suspension lift 6) Transfer brake shoes - If the retaining springs break. All are pretty easy to check out. |
Thanks Geo,
I've had a prybar around the rear ball joint, no play there. I swapped all bushes for the decent quality blue polyurethane ones about a year ago, all bolts etc were ok & copper slipped on re assembly, swapped all shocks to Koni heavy tracks whilst under there. Props OK, greased every 6 months or so, not lifted & doesn't see much abuse. Not checked pads though, but it does feel like drive line shunt & when I swapped the rear flanges this time last year, it improved for a bit, I'm assuming that the wear on the half shaft starts a bit of wear in the new flange and the rattle gets bigger! Much appreciated input though, if it warms up I might even swap the new Ebay take off parts across at the weekend and report back. Keith |
Just a bit of an update.
I removed the rubber cover on the half shaft hub, there's considerable play in the splines here. Ordered up a set today. Thanks for all the help, certainly saved me a lot of time tracing the play. This will be the first part (apart from routine servicing) ive had to replace on my defender, not bad going for 7 years and 165k kms ! Had good look round underneath today, very little wear, I'd say even the original brake pads should reach 200k kms no problem. |
