![]() | Home > My Defender > The FCX Defender 130 build thread |
Cut a hole .....
Sorry Steve
![]() I used a small drill bit, drilled around the perimeter and then finished off with a file. I've got a top of the range all singing all dancing Dremel and the poxy thing wont allow me to open the chuck ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Forgiven. ![]() ![]()
I was thinking one of those would be ideal yet never owned one. Seems it wasn't much good this time. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
I pondered for ages between the 'Genuine' Dremel and a much cheqper 'copy', might as well have gone for the copy as I've only used it a handful of times and now it's
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Blimey Matt, just seen this thread you've been busy. Great work.
Looking forward to seeing her again and Zagging her soon... |
Hello mate, yes I have
![]() I think it may still be a bit cold to Zag her yet ![]() ![]() |
jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 ![]() |
Hi Matt,
Your doors look well silenced. Did you Dynamat the door skin, then Dynamat over the polythene barrier and Dynalined over that? The doors must close like a BMWs now. |
Hi,
On the Puma they no longer have a polythene barrier, it's just a material very similar to the Dynaliner. I removed and discarded the LR stuff, Dynamat'd the door skin itself, then Dynamat'd where the LR stuff was and then Dynaline'd on top of that, they sound great and now they're bullet proof as well ![]() ![]() |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
It makes all the difference doesn't it ![]() ![]() BTW I saved up and have now got one of those wing locker lock covers ![]() |
Yes it does, thank you for supplying the stuff
![]() I've finished both doors on the drivers side and started on the passenger rear door. |
Matt have your wired the relay to your a/c? |
Not yet, do you know the wire colours on the aircon switch ? (or is that why you're asking me
That's why I am asking
