Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
I saw my old one the other day covered in mud with dogs in the back
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 ![]() ![]() ![]() |
Yeah where's that Grumpy Old Man thread.
I was going to get me rag out there and then - blimmen disgrace ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
My Defender mainly passed its MOT today. With 4 advisories
1. OSF seatbelt starting to fluff 2. slight movement in rear seat backs 3. slight corrosion to front and rear metal brake pipes 4. slight play in top of steering column 5. front wiper arm linkage worn 166649 miles old or a 1999 model 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
I've just replaced the wiper motor and two wheel boxes on mine and the difference is unbelievable. If you've had an advisory on it in my opinion it's £150 well spent
Is the wiper arm linkage not replaceable on its own? I've not looked into fixing.
What are the two wheel boxes? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Ill try and get a pic of all the removed bits in the light tomorrow if you want.
That would be ace - cheers 1999 Defender TD5 110
I think the linkages can be replaced on their own... but I may be wrong!
Don't know if this picture is of any use, but it shows the whole system... ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Cheers - are the wheels the bits that drive the wiper arms? 1999 Defender TD5 110
Kev stephenson Member Since: 27 Feb 2012 Location: Huddersfield Posts: 56 ![]() ![]() ![]() |
I've got 2 wheel boxes for a 1999 defender just sitting in my workshop. I sold the 1999 a couple of years ago and the 2005 is a different fit. Yours for the cost of postage. Let me know. 2005 110 TD5 XS running Alive Stage 1 and a bit and other toys
1996 130 300TDi chip truck for tree surgery business |
totalal Member Since: 26 Dec 2012 Location: Pembroke Posts: 36 ![]() ![]() ![]() |
Certainly are, attached to the outer end of the wheel boxes are the spindles, which the wiper arms are attached to ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
excossack, In case its of any help, ive just nipped into my garage to take some pictures of my spare 300tdi bulkhead for you. Heres a close up of the wiper wheels/spindles on the inside. They just unbolt from the outside by the single nut at the base of the wiper arm. I assume they are the same for the puma?...
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
