Home > Maintenance & Modifications > Washers/Spacers for standard spare wheel mount.
x-isle
I'm going to have some 265/75's fitted to my standard Boost next week.
In preperation I want to sort out the spacers needed for the spare rack.
I'm guessing they don't need to be the full 30mm difference, just wondering how wide the washer/spacers need to be?
Thanks all! Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #209452 8th Feb 2013 10:33am
foxkilla
United Kingdom 2008 Defender 110 Puma 2.4 USW Auto Tonga Green
on my disco2 I used shock absorber bushes as washers.
Post #209458 8th Feb 2013 10:49am
SteveG
2005 Defender 90 Td5 CSW Belize Green
One option is to just use LR steel wheel nuts as spacers.
Steve
Post #209460 8th Feb 2013 10:52am
How about none
ITs a Boost on there with a 265-75-16 KM2
Post #209461 8th Feb 2013 10:54am
x-isle
Thanks all for the tips.
Ken, so your tyre doesn't foul the wiper? Craig Rogers
2007 Puma 110 XS
Post #209464 8th Feb 2013 10:57am
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
My 265 AT's on Boosts don't foul the rear wiper (2001 TD5) Thumbs Up
Post #209466 8th Feb 2013 11:03am
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
The stock wheel carrier has "washers" on it, they are the galvanized bolt plates that look as big hexagonal (?) washers turned all the way towards the holder plate.
If you turn these out you can adapt according your needs.
pics would help but dont have any at hand.
Smile
Post #209469 8th Feb 2013 11:13am
x-isle
Smile
I've seen a photo of them, mine has washers, but they are just washers, they are not threaded. Craig Rogers
2007 Puma 110 XS
Post #209470 8th Feb 2013 11:14am
My 265 GG AT2 fouled the wiper arm so I used some standard steel wheel nuts under the large flat nuts that were already on the carrier:
 Darren
Post #209487 8th Feb 2013 12:16pm
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
4mm thick is what you need.
The carrier bolts on the new ones aren't adjustable and a washer is the only easy solution.
Post #209495 8th Feb 2013 1:36pm
x-isle
Bow down Thumbs Up Craig Rogers
2007 Puma 110 XS
Post #209497 8th Feb 2013 2:04pm
x-isle
I knew there's a reason I don't get rid of things.
I had an old Mountain Bike Handlebar lying around spare and it's perfect diameter.
So, i cut 3 sections 10mm in length then tidied them up with a bench grinder/wire wheel and voila! Perfect.
 Craig Rogers
2007 Puma 110 XS
Post #211742 16th Feb 2013 7:16pm
