![]() | Home > Maintenance & Modifications > Washers/Spacers for standard spare wheel mount. |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
I'm going to have some 265/75's fitted to my standard Boost next week.
In preperation I want to sort out the spacers needed for the spare rack. I'm guessing they don't need to be the full 30mm difference, just wondering how wide the washer/spacers need to be? Thanks all! Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
foxkilla Member Since: 01 May 2009 Location: J23 M1 Posts: 156 ![]() ![]() ![]() |
on my disco2 I used shock absorber bushes as washers.
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 675 ![]() ![]() |
One option is to just use LR steel wheel nuts as spacers.
Cheers Steve |
How about none
![]() Click image to enlarge ITs a Boost on there with a 265-75-16 KM2 |
Thanks all for the tips.
Ken, so your tyre doesn't foul the wiper? Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
TR51 Member Since: 17 Apr 2012 Location: Dorset UK Posts: 333 ![]() ![]() ![]() |
My 265 AT's on Boosts don't foul the rear wiper (2001 TD5)
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 ![]() ![]() ![]() |
The stock wheel carrier has "washers" on it, they are the galvanized bolt plates that look as big hexagonal (?) washers turned all the way towards the holder plate.
If you turn these out you can adapt according your needs. pics would help but dont have any at hand. ![]() |
I've seen a photo of them, mine has washers, but they are just washers, they are not threaded. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
My 265 GG AT2 fouled the wiper arm so I used some standard steel wheel nuts under the large flat nuts that were already on the carrier:
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 ![]() ![]() ![]() |
4mm thick is what you need.
The carrier bolts on the new ones aren't adjustable and a washer is the only easy solution. |
![]() ![]() 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
I knew there's a reason I don't get rid of things.
I had an old Mountain Bike Handlebar lying around spare and it's perfect diameter. So, i cut 3 sections 10mm in length then tidied them up with a bench grinder/wire wheel and voila! Perfect. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
