Home > Puma (Tdci) > 235/85/R16 pressure
doberman
United Kingdom 2012 Defender 110 Puma 2.2 USW Galway Green
235/85/R16 pressure
Hi I have conti cross contacts AT on my 110 utility what would you say the correct pressure should be ? I do carry a fair bit on weight in it + I have a heavy duty full 10'6" roof rack
Post #209455 8th Feb 2013 11:43am
MartinK
Manual says fronts are always 30psi irrespective of loading - that works fine for me Thumbs Up
Manual says Rears should be 48psi (normal loads) and 65psi (fully laden)
If you do that you'll have no fillings left Whistle
I use 40 psi in the rears normally...would increase that if I was carrying heavy loads for long distances. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #209462 8th Feb 2013 11:56am
SteveG
2005 Defender 90 Td5 CSW Belize Green
You can get a pice of chalk, mark across tyre, drive half a mile and see where it wearing and inflate/deflate to adjust. This gives optimum pressure for your weight.
Obviously doesn't work when it's raining! Wink Wink Wink
Post #209463 8th Feb 2013 11:56am
rossy
Yep 30 at the front and 40-42 ish at the back. 48 seems crazy. After 24k kms the wear on my back tyres is even. In fact they've hardly worn at all. Smile
Post #209531 8th Feb 2013 6:14pm
32 Front 38 Rear IIRC that's what mine run at. Perfectly happy with that. Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #209533 8th Feb 2013 6:19pm
foxkilla
United Kingdom 2008 Defender 110 Puma 2.4 USW Auto Tonga Green
30-40 for me
reinflate at 28-38
Very Happy
Post #209557 8th Feb 2013 7:09pm
excossack
36psi front and rear on my 235/85 R16s BFG ATS (110 TD5) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #209667 8th Feb 2013 10:30pm
doberman
Cheers guys
Post #210852 12th Feb 2013 11:58pm
jst
30 front and 45 rear on my USW or 65 for long trips rear or loaded with rack/trailer in BFG ATs. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #210869 13th Feb 2013 8:08am
