![]() | Home > Puma (Tdci) > 235/85/R16 pressure |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2671 ![]() ![]() ![]() |
Manual says fronts are always 30psi irrespective of loading - that works fine for me
![]() Manual says Rears should be 48psi (normal loads) and 65psi (fully laden) If you do that you'll have no fillings left ![]() I use 40 psi in the rears normally...would increase that if I was carrying heavy loads for long distances. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) Last edited by MartinK on 8th Feb 2013 11:57am. Edited 2 times in total |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 675 ![]() ![]() |
You can get a pice of chalk, mark across tyre, drive half a mile and see where it wearing and inflate/deflate to adjust. This gives optimum pressure for your weight.
Obviously doesn't work when it's raining! ![]() ![]() ![]() |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
Yep 30 at the front and 40-42 ish at the back. 48 seems crazy. After 24k kms the wear on my back tyres is even. In fact they've hardly worn at all.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
32 Front 38 Rear IIRC that's what mine run at. Perfectly happy with that.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
foxkilla Member Since: 01 May 2009 Location: J23 M1 Posts: 156 ![]() ![]() ![]() |
30-40 for me
reinflate at 28-38 ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6020 ![]() ![]() ![]() |
36psi front and rear on my 235/85 R16s BFG ATS (110 TD5) 1999 Defender TD5 110
doberman Member Since: 05 Aug 2012 Location: Cambridgeshire Posts: 53 ![]() ![]() ![]() |
Cheers guys
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8366 ![]() ![]() ![]() |
30 front and 45 rear on my USW or 65 for long trips rear or loaded with rack/trailer in BFG ATs. Cheers
