Home > Technical > Diffs
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Diffs
Why wont my 110 Rear Diff fit in the 90 Question Original Member Pie n Pea Club.
110 HCPU Tipper
Post #208387 4th Feb 2013 9:01pm
Glynparry25
I am sure someone will correct me if I am wrong, but the rear diff in the 110 is a P38 type (Heavy duty) where the 90 has a standard Rover 24 spline type diff.
the P38 diff replaced the Sailsbury diff on the older 110s. They only fitted the rover diffs to the 90s as they didn't eat them like the 110s did.
Glyn Dog Sheep
Post #208388 4th Feb 2013 9:09pm
Because the 90 use a Rover pattern diff and the 110 uses a P38 diff.
The P38 was used originally since it was the only Rover-made 4-pinion diff available at the time. Now of course there is a 4-pinion Rover diff (as used in the front axle) but the P38 is still used in the rear.
Post #208389 4th Feb 2013 9:13pm
willy eckerslike
And whats the physical difference, bigger i expect Original Member Pie n Pea Club.
110 HCPU Tipper
Post #208392 4th Feb 2013 9:16pm
ZeDefender
Always interesting stuff on this forum Thumbs Up Tell someone you love them today because life is short.
Post #208394 4th Feb 2013 9:24pm
ibexman
I think it can be machined to fit Thumbs Up
Post #208396 4th Feb 2013 9:30pm
willy eckerslike
Reckon I'll just send my 110 locking diff back to Crown Differentials and get it rebuilt into a 90 Diff, he enjoys it, already swapped it from a 90 to a 110 he can now swap it back again. Laughing Original Member Pie n Pea Club.
110 HCPU Tipper
Post #208399 4th Feb 2013 9:35pm
Glynparry25
Not really any bigger, but the housing on the P38 is shorter and has a different bolt configuration.
Here is a picture of the 2:
If you speak to Ashcroft- I do believe the rover diff can be made to fit the 110 housing with the addition of a spacer plate but not the other way around.
I am guessing you have some sort of locker? If so more than likely there will be a spacer ring http://www.ashcroft-transmissions.co.uk/in...ductId=128
Glyn Dog :sheep:
Post #208405 4th Feb 2013 9:38pm
