Home > My Defender > The FCX Defender 130 build thread
Page 13 of 25 <123 ... 121314 ... 232425>
Hi Matt,
Does this box use the same fixing positions as the original blanked off grill? If so, would it not fit over the top of chequer plate like I've done with my grill here:
A spongy foam gasket could be used to take up the 'bumps' of the chequer surface.
On a different tack, given that you've obviously got access to metalwork fabricators, is there scope for an improved 'FCX' version? Darren
Post #208223 4th Feb 2013 12:01pm
Hi LRA,
It's not the top that's an issue, it's the 'body' of the box wont fit through the hole in the chequerplate if that makes sense.
I did think about producing an FCX version (and I believe I could do it cheaper) however I'd rather not 'rip off' other peoples ideas as such however if I come up with something that serves the same purpose but is approached from a different viewpoint then you guys will be the first to know Thumbs Up
Post #208229 4th Feb 2013 12:10pm
Ah, I see what you mean. S'funny - most chequer plate I've seen is like mine with the notable exception of the Entreq ones. I wonder if the GMB box was designed with that in mind?
I was quite interested in one of these boxes but not if I have to start hacking the chequer plate around. If there was an alternative available that overcame the problem (and was cheaper!) then it would be very appealing... Whistle Darren
Post #208235 4th Feb 2013 12:21pm
I agree, all of the chequerplate I had access to yesterday was exactly the same Confused
I'm sorry to 'quash' a sale for Mud but glad to have saved you the disappointment of not being able to fit easily Thumbs Up
Post #208241 4th Feb 2013 12:30pm
SGH
Matt
You should have got one of these to go in box..
Post #208247 4th Feb 2013 12:54pm
I looked at those but I've already got the Anderson set up on other vehicles and it's handy to be able to swap leads about - I also read somewhere that the Military set up shown suffers a lot from corrosion ....
Post #208249 4th Feb 2013 12:58pm
SGH
TBH
GMB Locker would look better with chequer plate that fits around it rather than under it as IMHO it sits too high and looks odd.
Post #208250 4th Feb 2013 12:59pm
I'm afraid I have to agree, I am quite disappointed, another 'issue' is that when the rubber lock cover is fitted this effectively moves the lock up and therefore makes it really hard to engage Confused
Post #208255 4th Feb 2013 1:08pm
SGH
No cover on my lock :?
Post #208256 4th Feb 2013 1:10pm
It was a £3 extra - tight wad ! Rolling with laughter
Post #208259 4th Feb 2013 1:12pm
SGH
Big Cry Big Cry Big Cry
Post #208262 4th Feb 2013 1:16pm
The whole weekend spent on the FCX 130, a few pics of stuff done:
Post #210342 11th Feb 2013 10:16am
Coming along nicely Matt. Is that a temp gauge you've put in the dash now? ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #210343 11th Feb 2013 10:27am
Its the 'Checktime' unit from Mobile Centre, supplys internal and external temperature and consequently turns airconditioning into a type of climate control
http://www.mobilecentre.co.uk/index.php?ma...cts_id=654
http://defender2.net/forum/topic14933.html...te+control
Post #210348 11th Feb 2013 10:38am
I know the one. Looks good. How did you fit it? ____\We|Will|Win/___
Post #210352 11th Feb 2013 10:44am
