Home > Maintenance & Modifications > Goodwinch (aircon) winch bumper
BigMike
Does anyone happen to have one of these? If so, and you have a steering guard, does the SG need to be modified to fit or not? if not, what's the make/model of steering guard you have? I've just taken off my SG because the brackets need grinding out to fit and frankly it's going to weaken the guard significantly so I need a new one.
Post #50351 30th Dec 2010 6:37pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
not mine but i found it on his website
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2004 TD5 Defender 90 xs station wagon
Post #50719 2nd Jan 2011 4:37pm
BigMike
Thanks John but perhaps I wasn't clear enough. I already have one, my normal steering guard won't fit with it unless I grind out the SG brackets. I want a new steering guard which will fit with it without modding.
Post #50943 4th Jan 2011 12:10am
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
Sorry for digging this old thread up BigMike. But am having similar problem.
What steering guard (if any) did you end up with?
Post #207884 3rd Feb 2013 8:56am
BigMike
I honestly can't remember, Rakthi. I sold the 90 in Sep 2011.
Post #207936 3rd Feb 2013 11:46am
Rakthi
Was worth a try ... Thanks for answering.
Maybe one of the local metal guys can figure something out.
Stephan
Post #207979 3rd Feb 2013 1:47pm
BigWheels
Too bad a GW bumper can't be made to fit that doesn't foul/isn't fouled by a steering guard, given that vehicles that use winches are on the rough more... Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #208448 4th Feb 2013 11:20pm
Rakthi
Got me a cheap one and will see what needs to be done to alter it so it works with the GW bumper.
SInce they are all basically the same I can then work out from there how to go. If it is too involved, will take it to one of the local welders and have him make me one. At least he will have a template with the right dimensions for the bolt holes. Won't be laser cut etc. but it sure will do the job..
Would like to have one by the start of the rainy season, some tracks here turn to soapy sludge and there are lots of small to medium sized boulders hidden between the ruts.
Post #208470 5th Feb 2013 4:45am
jst
i have a goodwinch non a/c bumper with a Southdown steering guard. all fits fine, no mods needed. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #208537 5th Feb 2013 3:59pm
bell-auto-services
I may be wrong but I think GW bumpers are now made here http://www.landy-spares.com/ they may be able to help ?
Pete
Post #208540 5th Feb 2013 4:28pm
Rakthi
@ jst - had read about Southdown fitting with the GW bumper, but Southdown sold that part of their business to Allmakes ... no clue now where to get one now. The "Shadow" ones offered by FirstFour seem similar. So will keep that in mind.
@ Pete - Thanks for that link. Will see if I can get one fabricated/adapted locally. If they can't, will mail those guys.
Thanks guys! Appreciate the help! Sometimes wished I was not so far away. So much easier to get stuff.
Post #208781 6th Feb 2013 2:47am
Rakthi
Update
The budget steering guard (Part Number - FFSGBDEF) sold by First Four fitted without too many complications.
Had to cut off the recovery eye of the right hand side support so I could get the bolt through. Strangely enough the left side fitted without this modification but it was a close fit.
The actual plate itself just misses the bolts that hold in the winch itself and in effect almost making it impossible to unbolt the winch without removing the steering guard.
I'll leave it on for now and see how it holds up.
Post #214117 25th Feb 2013 11:01am
