![]() | Home > Td5 > Anybody fitted a rev counter? |
| Perc Member Since: 25 Jan 2013 Location: Westcoast Posts: 18
Never trust the guy with the shiny gear Thanks for your quick reply! I've tested to measure with the probe grounded to the wire to pin 24, I'm sure that there is good contact, but the result are the same. I work with electrical systems on pleasure wessels so I'm familiar with measuring. I've also checked so there is proper contact between pin 19 and my wiring. It's a little bit confusing. Per CSW 90 -03 |
| me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856
Might be a stupid question but which plug are you looking at?
The black one.
There are no stupid questions |
Scale: 50mV/div and 20 mS/div, so the signal (or noise) is weak. I have tested to put ground on pin 24 with no difference. I haven't found the joint for grounding the ECU, i think that's the only thing not tested. I'm sure that I found pin 19.
This weekend I'm away from home, will continue to solve the problem next week. There are also an option to made an W on the alternator... but I thougt that pin 19 would be easier... Give up is not an option.... Per CSW 90 -03 |
| nfgp Member Since: 05 Jan 2012 Location: Portugal Posts: 3 |
Hi guys,
To bring back to life this topic, did anyone did this mod with sucess? Regards |
| chinnus Member Since: 24 Aug 2012 Location: UK Posts: 119
nope still waiting to find a cheap part haha!!
| Brucey Member Since: 18 Jul 2012 Location: Warsaw, Poland Posts: 61
Question for Davew i guess I tried to build the circuit as described. Just installed and i get some strange results! I have a td5 with ABS, an autobox with compushift. With ignition on and engine not running. My compushift rpm is showing 180 rpm. With engine running it shows about 180 rpm lower than actual (as shown on the nanocom). Any ideał what i have done wrong? Just re-reading this thread, i did not check if the pin19 is outputting 12v or 5v. Chris Defender 110 DC converted Auto BMW R1200GS BMW F650GS Dakar |
| keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2279
Yep my TD5 rev counter took the place of the clock and the clock went in a pod where the rear view mirror goes .
If you disconnect the ECU pin but leave the supply on the circuit and the connection to the compushift what does it say? www.td5.org |
Ok, cut the feed from pin 19 (yellow/purple). Compushift shown zero.
Output from the disconnected ecu wire is strange. Engine not running is cycling either side of 5v (about 1v) so on multimeter is going from 4v (climbs rather than jumps) to 6v and back continuously but slow enough that the multimeter can show it. Chris Defender 110 DC converted Auto BMW R1200GS BMW F650GS Dakar |
| davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888
The 180 ish RPM is "normal" for the TD5 ECU, no idea why but they all do it - I thought I'd mentioned it somewhere in this thread before. Putting a scope on it will show it is actually putting out a square wave whenever the ignition is on, I've always assumed that it's because the pin we're using was intended to be used by the ABS and the ABS ECU uses it to confirm communication with the TD5 ECU or something.
Not really noticed a difference between Autologic and the TD5 ECU output (not really looked that closely TBH) but not compared it to Nanocom... will try and remember to do that on Pam's tomorrow. It might well be because the output is artificially generated by the ECU - it's probably not high on the list of things to be done accurately by the ECU as it's producing a 4 cylinder signal on a 5 cylinder engine. http://www.yorkshireoffroadclub.net/ |
Hmmmm, but if the nanocom can pick up an accurate reading from the diagnostic socket, cannot we pick up that signal also??? Defender 110 DC converted Auto BMW R1200GS BMW F650GS Dakar |
Not directly as it acts as a server retrieve the information. www.td5.org
OK, the clue was in the last sentence of Dave's comments above. I had my Compushift set up as a Td5 (i.e 5 cylinders) so change the Compushift setting to four cylinders and the RPM is close enough to be not worth digging further. It now shows 230 rpm when engine off and the RPM is around 25 lower than shown on the Nanocom, but it's close enough. Thanks all for your comments Chris Defender 110 DC converted Auto BMW R1200GS BMW F650GS Dakar |
