Home > Td5 > Anybody fitted a rev counter?
Page 3 of 5 <12345>
Brucey
Poland 2004 Defender 110 Td5 DCPU Auto Java Black
Ok, I know that I am lazy and could search myself, but where do I buy such components? I have a Compushift on a ZF auto box and would like to give a signal to the RPM wire. Do I use the circuit given above by Dave? Idiot's guide needed. Embarassed
Hmm I'll see if I can find an electronics shop locally, but explaining what I need in Polish will be fun!
Chris Defender 110 DC converted Auto
BMW R1200GS
BMW F650GS Dakar
Post #191533 7th Dec 2012 11:24am
davew
RS online will have them...
http://www.rs-online.com/index.html
The easiest way to build it is to use some Veroboard and build the circuit on that. Was it you that was asking on D44 ?
I used that circuit on Pam's TD5 to drive the Compushift tacho, I can't remember the exact values of resistors I used but I can take a look this weekend. http://www.yorkshireoffroadclub.net/
Post #191540 7th Dec 2012 11:43am
Brucey
No, not me asking before, it was the thread that prompted the idea!
Any guidance would be great, thanks in advance.
So, the ECU pin 19 is the Transistor trigger, switched 12v and ground needed. Transistor ant two resistors...sounds easy enough electrics even for a failed mechanical engineer! Embarassed
BMW R1200GS
BMW F650GS Dakar
Post #191543 7th Dec 2012 11:48am
davew
Had a look at the one I built for Pam's 90, I used 1K ohm resistors for both. http://www.yorkshireoffroadclub.net/
Post #191815 8th Dec 2012 3:53pm
Brucey
Great, thanks for taking the trouble Dave. I just need the bits now!
Thanks again.
BMW R1200GS
BMW F650GS Dakar
Post #192659 11th Dec 2012 10:22am
Perc
Sweden 2003 Defender 90 Td5 SW Oslo Blue
Hello, this is my first post, live in Sweden.
I have tried to connect a tacho as shown by davew but it did'nt work (yet). A friend tested pin 19 with an ocilloscope but culd'nt detect any signal. My 90 is not equipped with either TC or ABS. Could it be so that the ECU needs some programming to deliver a signal on pin 19.
Per CSW 90 -03
Post #205536 26th Jan 2013 4:11pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
It shouldn't make a difference, my 90 was base spec too and pin 19 worked.
Post #205674 26th Jan 2013 9:16pm
Perc
Thanks!
OK, I had to check up so I have a proper contact on the earth side.
Did anyone measured the signal with an ocilloscope?
Per CSW 90 -03
Post #205677 26th Jan 2013 9:22pm
davew
Are you SURE you were using pin 19 ? I ask because the pin layout isn't straight forward and it's very easy to get it the wrong way around. The middle row of pins is numbered the opposite way around to the top and bottom rows so pin 18 and 19 are very easy to get transposed. http://www.yorkshireoffroadclub.net/
Post #205681 26th Jan 2013 9:35pm
Perc
I think so, I've had checked and doublechecked against the chart over the plint. Tomorrow i will check again from your approach that they are easy to mix up.
Thanks for your support!
/Per CSW 90 -03
Post #205683 26th Jan 2013 9:41pm
SteveG
Perc wrote:
Thanks!
Per
Were you using an analogue scope? I suspect the signal is probably digital.
Post #205692 26th Jan 2013 10:11pm
Perc
I don't know, it was a friend of mine who measured, he works with repair of car-audio, and is familiar how to use a scope. He said that he saw mostly "noise".
/Per CSW 90 -03
Post #205694 26th Jan 2013 10:17pm
davew
It will be fine digital or analogue scopes will work, not sure if SteveG is pulling your leg or not TBH.
Tell your friend he should see a 5V square wave with 2 pulses per revolution so it's pretty slow by audio standards - at 300RPM you're looking for a 10Hz signal (600 ppm, 10 pps). With the engine not running and the ignition turned on you often see a signal that equates to around 200RPM. As far as I remember the pulses are evenly spaced because the signal is generated by the ECU, it's a fully artificial signal, not directly linked to the engine as such. http://www.yorkshireoffroadclub.net/
Post #205702 26th Jan 2013 10:34pm
Perc
I have checked a little...
Pins: pin 18 - pink, pin 19 the new cabel fitted by me, pin 20 a red cabel, that seems to be correct.
I bought a small oscilloscope and tested, last time I used a oscilloscope was 40 years ago, but i think i remember how to use it. I've got the following picture
As far as I can read out the signal is about 100 mV and 30 Hz, this is when idling. The curve changes when you throttle.
I think that pin 19 is not programmed om my ECU, what do you think?
Per CSW 90 -03
Post #206532 29th Jan 2013 3:12pm
davew
That looks like noise to me, the signal you are looking for is much bigger and slower than that. You want to be looking at 50ms-100ms on the timeline and 1v per division on the vertical. Make sure the probe is earthed to the same point as the ECU and that the display is visible when you touch the probe to earth.
I've not come across an ECU that doesn't have that output and I've not found any settings that would turn it on/off when playing around with the Autologic diagnostics/programmer. Having said that though, there's always a first time !
If it stops raining this weekend I'll put a scope on mine and get a picture, have to say my scope is a lot more basic than that one though Embarassed so you have to promise not to laugh ! http://www.yorkshireoffroadclub.net/
Post #206534 29th Jan 2013 3:40pm
Page 3 of 5 <12345>
