Home > Puma (Tdci) > Fitting a winch?
Page 2 of 2 <12
Glynparry25
Just a quick question:
You say you want to mount a winch and a tow ball to your front bumper......... If the winch is the same height as the tow ball your winch rope would have to go up and over the headboard/ top part of the flat bed which means it won't be workable.
If for recovery- as above get a smaller winch mounted to the trailer and Anderson connectors- it also means you just pull up, winch whatever onto the back, strap down and drive off- no need to mess around un-hitching, turning around, re-hitching, winching, strapping down, un-hitching, turning around, re-hitching, driving off.
If winching a vehicle with trailer (3.5 ton) out of a field you don't need anything massively chunky as you will not be 'properly bogged in'. Something like a simple 4 ton (metric) winch with a snatch block will do the trick. But also think about what you are going to winch off...... you will have to think about ground anchors etc. A cheaper option will be to look into waffle boards/ sand ladders/ traction mats as then you just throw them down in the areas you are likely to lose traction.
HD springs- again as above- wait and see how she feels before worrying about it. I have a TJM bull bar with Warn 8274 which is very heavy- it took 2 years for the front springs to get really tired and needed changing.
Glyn Dog Sheep
Post #205815 27th Jan 2013 9:41am
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
“I would not fit a winch without heavier rated springs”
It depends how long you intend to keep the vehicle… If you’re gonna thrash it and it’ll be gone in a couple of years there’s not much to be gained.
My 110 TD5 (ROW HD spec but I think the front springs remain standard - the anoraks can confirm) was fitted from new with a Husky and, over time, the front of the truck DID sag.
Peter
Post #205946 27th Jan 2013 6:17pm
jst
you could go for a higher load TDS 12,000LB one, which would cope admirably. its normally only the gearing that is changed for a greater pull, they use the same motor.
current draws for different motors are also worth considering. the lower it is the less extra stuff the vehicle would need for prolonged winching ops. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #206236 28th Jan 2013 2:55pm
BigMike
Go Beyond wrote:
Alternatively use a snatch block to effectively halve the load on the winch (although halve the speed as well) and get a smaller 8 / 9000lb version
This one again. You're not halving the load, you are halving the AMPS only. And depending on how many wraps are on the winch, the speed is actually unlikely to halve as there are less amps being used. It's a little slower but not half.
And I totaly disagree with "standard springs". If you put a winch on your vehicle and don't change the springs it will handle like an absolute dog. A decent set of springs will still mean you can turn into corners quickly and the vehicle will stay planted. For the price of a set of springs it's frankly daft not to do it.
Post #206286 28th Jan 2013 7:24pm
jst
^^^ is correct.
in theory you halve the speed as twice the rope is out.
in reality as more ropes is off (remember you loose 1000lb for every layer on the drum) is easier going on the winch anyway, so current draw is less, plus you have the mech 2:1 adv. so speed will be slower but it wont be half. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #206310 28th Jan 2013 8:15pm
BigMike
The mechanical advantage - on paper it helps but the reality is that if you use a snatch block the angle of the rope is so acute that any advantage you get is reduced considerably. If the wheel part of the snatch block was say, a foot in diameter then sure, there would be an advantage, but tiny as they are, it's too tight to really give you much.
Anyway, HD springs are a must I say. I've driven defenders with and without HD springs with winches and can say that on standard springs the vehicle handles like a sofa sitting on a beachball at each corner
Post #206485 29th Jan 2013 10:11am
60k plus miles since I fitted a Husky (with wire rope) to my DC on standard springs.
No sag, no handling issues of any kind.
Post #206494 29th Jan 2013 10:49am
Glynparry25
I have to agree with blackwolf- I first had my husky and now my 8274 on standard springs and had no problems with general every day driving/ off-road. The shocks on the other had took a battering and ended up changing mine for OME and Koni after 35k miles because of the type of driving I do.
Now, yes it feels a little more planted when hitting the harder-faster stuff off-road but in all honesty I wouldn't go any faster around a corner on road.
Glyn Dog Sheep
Post #206504 29th Jan 2013 11:16am
BigWheels
I've been considering whether a synthetic rope would make much difference for occassional use. More weight lower = better centre of gravity & fairleads + wire give more front protection. Heavier weight makes it harder to lift, an anti-theft deterrent maybe. Steel also less vandalisable.
Whiplash from a snapped steel cable is dangerous, apron or no. Cheap to replace & less attractive... Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #209820 9th Feb 2013 3:06pm
Another thing to consider with synthetic rope is it deteriorates in sunlight so should either be covered or removed when not in use ....
Post #209826 9th Feb 2013 3:24pm
BigWheels
Dyneema says its ropes are UV proof, not sure about others. But the muck it picks up needs cleaning off while steel only needs oiling. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #209909 9th Feb 2013 7:45pm
jst
the colour deteriorates but the properties of it dont.
i would cover it or remove to keep the road grime off it though.
for occasional use i would keep wire, it requires less after care work/cleaning. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #210649 12th Feb 2013 8:27am
Undergroundfrog
United Kingdom 2009 Defender 90 Puma 2.4 HT Baltic Blue
speedymarktd6 wrote:
chadjizz wrote:
i am also thinking about getting a winch. just to chuck another question in the mix.... whats the max power winch you could run.... i have a 130 and tow trailer loads of fencing into feilds, so if i get stuck i could be winching min 3.5ton. im thinking a superwinch talon 18000lb (8ton) (http://www.ebay.co.uk/itm/120915766659?ssP...1423.l2649) or is that just going to rip the front bumper off!!!!!
I would go for a milemarker hyd of the power steering on a 130 there wouldnt be a lot in it price wise
Hmmm, mine is a MM hydraulic winch off the standard ps pump and it don't work in high at all, so be careful as you may be disappointed
Post #210811 12th Feb 2013 9:54pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
Using a snatch block on a double line pull will roughly halve the load. The angle is not too acute and you don't need a foot wide pulley block.
Steve
Post #210832 12th Feb 2013 10:41pm
Page 2 of 2 <12
