![]() | Home > Puma (Tdci) > Fitting a winch? |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 886 ![]() ![]() ![]() |
“I would not fit a winch without heavier rated springs”
It depends how long you intend to keep the vehicle… If you’re gonna thrash it and it’ll be gone in a couple of years there’s not much to be gained. My 110 TD5 (ROW HD spec but I think the front springs remain standard - the anoraks can confirm) was fitted from new with a Husky and, over time, the front of the truck DID sag. Peter |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8372 ![]() ![]() ![]() |
you could go for a higher load TDS 12,000LB one, which would cope admirably. its normally only the gearing that is changed for a greater pull, they use the same motor.
current draws for different motors are also worth considering. the lower it is the less extra stuff the vehicle would need for prolonged winching ops. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
This one again. You're not halving the load, you are halving the AMPS only. And depending on how many wraps are on the winch, the speed is actually unlikely to halve as there are less amps being used. It's a little slower but not half. And I totaly disagree with "standard springs". If you put a winch on your vehicle and don't change the springs it will handle like an absolute dog. A decent set of springs will still mean you can turn into corners quickly and the vehicle will stay planted. For the price of a set of springs it's frankly daft not to do it. |
^^^ is correct.
in theory you halve the speed as twice the rope is out. in reality as more ropes is off (remember you loose 1000lb for every layer on the drum) is easier going on the winch anyway, so current draw is less, plus you have the mech 2:1 adv. so speed will be slower but it wont be half. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
The mechanical advantage - on paper it helps but the reality is that if you use a snatch block the angle of the rope is so acute that any advantage you get is reduced considerably. If the wheel part of the snatch block was say, a foot in diameter then sure, there would be an advantage, but tiny as they are, it's too tight to really give you much.
Anyway, HD springs are a must I say. I've driven defenders with and without HD springs with winches and can say that on standard springs the vehicle handles like a sofa sitting on a beachball at each corner |
60k plus miles since I fitted a Husky (with wire rope) to my DC on standard springs.
No sag, no handling issues of any kind. |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
I have to agree with blackwolf- I first had my husky and now my 8274 on standard springs and had no problems with general every day driving/ off-road. The shocks on the other had took a battering and ended up changing mine for OME and Koni after 35k miles because of the type of driving I do.
Now, yes it feels a little more planted when hitting the harder-faster stuff off-road but in all honesty I wouldn't go any faster around a corner on road. Glyn ![]() ![]() |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
I've been considering whether a synthetic rope would make much difference for occassional use. More weight lower = better centre of gravity & fairleads + wire give more front protection. Heavier weight makes it harder to lift, an anti-theft deterrent maybe. Steel also less vandalisable.
Whiplash from a snapped steel cable is dangerous, apron or no. Cheap to replace & less attractive... Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
Another thing to consider with synthetic rope is it deteriorates in sunlight so should either be covered or removed when not in use ....
Dyneema says its ropes are UV proof, not sure about others. But the muck it picks up needs cleaning off while steel only needs oiling. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
the colour deteriorates but the properties of it dont. i would cover it or remove to keep the road grime off it though. for occasional use i would keep wire, it requires less after care work/cleaning. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Undergroundfrog Member Since: 27 Jan 2013 Location: Herts Posts: 31 ![]() ![]() ![]() |
Hmmm, mine is a MM hydraulic winch off the standard ps pump and it don't work in high at all, so be careful as you may be disappointed |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 675 ![]() ![]() |
Using a snatch block on a double line pull will roughly halve the load. The angle is not too acute and you don't need a foot wide pulley block. Cheers Steve |
