Home > Maintenance & Modifications > Half width dog/load guard? |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 |
If you are talking about half height (just the top part) here's how I did it using a standard two part kit. http://www.defender2.net/forum/topic13077....=dog+guard You could probably do that with a 300tdi one, although I seem to recall it was either bulk head fixing or a full size all in one which you'd need to chop.
Not sure what you'd be able to fix a 1/2 width one to. If you have a bulk head you could use one of those lengthwise dividers and chop a full width in half, but might be a bit of a bodge unless you metal work skills are far better then mine! Not a geat deal of help really but I'm thinking 1/2 height which is probably not what you want when you say 1/2 width. DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
25th Jan 2013 6:41pm |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 |
How about taking a full size one, and modifying it, making removable sections?
25th Jan 2013 6:45pm |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
A full width one with a "gate" modification seems a fairly easy option. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
25th Jan 2013 9:56pm |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 |
Exactly what i did with the full guard for the Disco. Puma 110 SW guard from Land Rover has a drop-down section where the middle seat is if that helps?
http://www.rimmerbros.co.uk/Item--i-GRID007372 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
25th Jan 2013 10:05pm |
I suspect that this isn't quite what you're after either but I'll offer it anyway just in case: I made a bulkhead for behind the 2nd row seats in my station wagon and then mounted a half-height guard intended for one with a bulkhead behind the front seats on top. This top part can be removed very easily if I need to carry something longer, and the bulkhead itself can also be taken out by undoing four bolts that fit to existing threaded inserts.
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
26th Jan 2013 12:41am |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 |
Thanks for the replies.
I'd really like to be able to put my bike inside without having to remove a wheel. If one end of the guard was missing then i could fold down one of the end 2nd row seats and the bike would fit down one side of the 110 I guess for a strong fitting, a half width wouldn't work? I might have to butcher my full size guard but it seems a shame really. |
28th Jan 2013 8:58pm |
