![]() | Home > Maintenance & Modifications > Half width dog/load guard? |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
If you are talking about half height (just the top part) here's how I did it using a standard two part kit. http://www.defender2.net/forum/topic13077....=dog+guard You could probably do that with a 300tdi one, although I seem to recall it was either bulk head fixing or a full size all in one which you'd need to chop.
Not sure what you'd be able to fix a 1/2 width one to. If you have a bulk head you could use one of those lengthwise dividers and chop a full width in half, but might be a bit of a bodge unless you metal work skills are far better then mine! Not a geat deal of help really but I'm thinking 1/2 height which is probably not what you want when you say 1/2 width. DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 ![]() ![]() ![]() |
How about taking a full size one, and modifying it, making removable sections?
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
A full width one with a "gate" modification seems a fairly easy option. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
Exactly what i did with the full guard for the Disco. Puma 110 SW guard from Land Rover has a drop-down section where the middle seat is if that helps?
http://www.rimmerbros.co.uk/Item--i-GRID007372 ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
I suspect that this isn't quite what you're after either but I'll offer it anyway just in case: I made a bulkhead for behind the 2nd row seats in my station wagon and then mounted a half-height guard intended for one with a bulkhead behind the front seats on top. This top part can be removed very easily if I need to carry something longer, and the bulkhead itself can also be taken out by undoing four bolts that fit to existing threaded inserts.
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Thanks for the replies.
I'd really like to be able to put my bike inside without having to remove a wheel. If one end of the guard was missing then i could fold down one of the end 2nd row seats and the bike would fit down one side of the 110 I guess for a strong fitting, a half width wouldn't work? I might have to butcher my full size guard but it seems a shame really. |
