Home > Off Topic > Karcher HDS550
RED-DOT
Karcher HDS550
My Karcher is used rarely used for a deep clean of my Defender has developed a fault and was wondering if anyone here has or had the same fault? The machine pressures up to the running pressure instantly but when i press the trigger it only emits a few bar of pressure... Plenty supply and filters seem OK. Any help woud be great, ta! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #206129 28th Jan 2013 12:03am
Laurie
Check the flow into it.
It's restricted somewhere.
Post #206131 28th Jan 2013 12:07am
RED-DOT
Plenty flow to the tank and feed to the pump head. Friggin. Baffling. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #206133 28th Jan 2013 12:10am
Laurie
I had a faulty 'auto-shutoff' hoselock connector.
It worked fine on everything except filling my caravan tank and my pressure washer.
Try a different connector.
Post #206140 28th Jan 2013 12:23am
AlisterC
Wales 2011 Defender 90 Puma 2.4 XS CSW Indus Silver
I had the same issue as Laurie with an auto shut off head.
There is a little plastic cross in the connector that restricts the flow. Cut it out with a pliers and everything was fine
Worth a look
Post #206175 28th Jan 2013 9:03am
RED-DOT
I have crows foot straight through couplings and there seems to be plenty feed to pump heads. Machine reaches pressure then loses pressure when trigger is pulled. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #206202 28th Jan 2013 11:39am
K9F
Hi Red Dot,
Don't know if yours is the same but my Karcher must be at least 20 years old and still gives me great service. At the end of the nozzle I have what can only be described as a stainless steel reed valve which is two small flat pieces of steel that varies the water jet, when in use I have experienced when using it up close and the valve is open that grit and dirt can migrate between the steel plates and affect the nozzle pressure. If yours is the same you can either dismantle the end and flush it out or by using a small instrument screwdriver dislodge any crud caught between the steel plates.
Hope this helps. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #206206 28th Jan 2013 11:47am
MartinK
I had this on my Karcher 620. As it stays in the garage I assumed frost had broken it. After a complete strip-down and rebuild, I found no obvious fault. When I put it back together it all worked fine again Rolling Eyes
It's the one that looks like this:
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #206208 28th Jan 2013 11:51am
RED-DOT
Mine is a semi industrial hot water cleaner model HDS 550 and it was perfect prior to this problem. I have one the same as your 620 in the loft if you ever need parts? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #206210 28th Jan 2013 11:57am
WarPig
I wouldnt use one in the loft, water might leak through the ceiling below. Mr. Green
Ive read lots of reports of Karchers pulsing on and off, my previous one did it.
Post #206250 28th Jan 2013 3:36pm
rossy
If all else fails Red dot give them a ring at their Banbury HO and ask for technical. The one you have is a pretty decent one and they will be helpful. They tend to be very unhelpful if its the standard K2, K3 etc stuff on sale at DIY stores because they know they're garbage and built to a price - and anyway the B&Q, Homebase stuff is only a fraction of their market Wink
Post #206336 28th Jan 2013 9:08pm
