![]() | Home > Off Topic > Karcher HDS550 |
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
Check the flow into it.
It's restricted somewhere. ![]() |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363
Plenty flow to the tank and feed to the pump head. Friggin. Baffling. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
I had a faulty 'auto-shutoff' hoselock connector.
It worked fine on everything except filling my caravan tank and my pressure washer. Try a different connector. ![]() |
| AlisterC Member Since: 25 Apr 2012 Location: Somerset Posts: 116
I had the same issue as Laurie with an auto shut off head.
There is a little plastic cross in the connector that restricts the flow. Cut it out with a pliers and everything was fine Worth a look |
I have crows foot straight through couplings and there seems to be plenty feed to pump heads. Machine reaches pressure then loses pressure when trigger is pulled. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Hi Red Dot,
Don't know if yours is the same but my Karcher must be at least 20 years old and still gives me great service. At the end of the nozzle I have what can only be described as a stainless steel reed valve which is two small flat pieces of steel that varies the water jet, when in use I have experienced when using it up close and the valve is open that grit and dirt can migrate between the steel plates and affect the nozzle pressure. If yours is the same you can either dismantle the end and flush it out or by using a small instrument screwdriver dislodge any crud caught between the steel plates. Hope this helps. Treat every day as if it is your last....one day you will be right!! |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
I had this on my Karcher 620. As it stays in the garage I assumed frost had broken it. After a complete strip-down and rebuild, I found no obvious fault. When I put it back together it all worked fine again
It's the one that looks like this: Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Mine is a semi industrial hot water cleaner model HDS 550 and it was perfect prior to this problem. I have one the same as your 620 in the loft if you ever need parts? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. |
| WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748
I wouldnt use one in the loft, water might leak through the ceiling below. Ive read lots of reports of Karchers pulsing on and off, my previous one did it. |
| rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297
If all else fails Red dot give them a ring at their Banbury HO and ask for technical. The one you have is a pretty decent one and they will be helpful. They tend to be very unhelpful if its the standard K2, K3 etc stuff on sale at DIY stores because they know they're garbage and built to a price - and anyway the B&Q, Homebase stuff is only a fraction of their market
