Home > Maintenance & Modifications > Steering wheel column casing - put Puma one on TD5?
BigWheels
Sat in the driver's seat of a TD5 (looking at a 110). The steering column & its surrounding wires, switches etc are housed in a more rectangular casing - that sticks out each side its corners digging into my legs.
My Puma has a slimmer more oval casing. Is it possible to straight-swap a Puma casing with the TD5 one, or get an aftermarket slimmer one,..or something else. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #205348 25th Jan 2013 8:52pm
Killer90
Site Sponsor
Confused Confused i swear they are the same Question your talking about the plastic casing around the steering collum yes Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #205352 25th Jan 2013 8:54pm
SGH
Same up to chassis number DA431464
Post #205381 25th Jan 2013 9:52pm
The one on my '07 Puma even has the hole for the Series III 2286cc petrol engine choke cable!
Post #205403 25th Jan 2013 10:29pm
Killer90
Site Sponsor
which is the 2.2 Simon Question im gunna look at dads 90 now to see Thumbs Up CSK Automotive
Post #205404 25th Jan 2013 10:30pm
The casings are identical on TD5's and Pumas, it's an optical illusion because the dash in a Puma comes further forward and covers more of it. You sit in the same position relative to both steering columns as well ....
Post #205415 25th Jan 2013 11:02pm
BigWheels
I was bruising my inner knees on the TD5. Doesn't happen with my Puma. Confused Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #205487 26th Jan 2013 11:03am
Did it have seat risers fitted ?
Post #205488 26th Jan 2013 11:08am
BigWheels
NOt as far as I know. Had a rear bulkhead (I would remove if bought the 110) Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #205493 26th Jan 2013 11:25am
Did you get to the bottom of this ?
I was intrigued after reading your post and as I have a 300TDi, TD5, 50th V8 and a Puma I took basic measurements of all four and they are all identical.
Identical seat box position in 90's and 130's (dont have a 110 currently), identical steering column casings, identical distance between column and bulkhead ????
Post #206762 30th Jan 2013 9:44am
