![]() | Home > Off Topic > Mapping Software on Ipad |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
You will if the maps are compatible. If your maps don't work with the current version of MemoryMap on your PC they probably won't work on the iPad.
If they do work, you can copy them onto the iPad via the Applications tab in iTunes. http://www.yorkshireoffroadclub.net/ |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Do you have wifi model ipad or one on a contract ?
If you only have wi-fi model you might want to get one of these http://bad-elf.com/products/be-gps-1000/ and email them to see if compatible with MM. 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
I have old V4 maps and installed latest Mem-Map app and copied maps to iPad from PC.
All works fine.. ![]() Cheers Simon Ps mine is GSM model, bought so it had GPS built in.... |
Chauch Member Since: 10 Dec 2011 Location: Bedfordshire Posts: 51 ![]() ![]() ![]() |
If you have the 3G and travel predominantly in mobile signal areas, the free Outside app is superb....
Projectblue Member Since: 22 Nov 2011 Location: Devon Posts: 1096 ![]() ![]() |
It's only the wi-fi version. I can tether it to my mobile or, have pda with gps (which I'm currently running MM v4 on, hence having the maps).
trouble is, the old eyesight isn't what it used to be, so the bigger ipad screen would be ideal. Chauch - I don't and it's precisely for non mobile sig areas that i need the better standard of mapping ![]() thanks for the answers so far. ![]() |
"trouble is, the old eyesight isn't what it used to be, so the bigger ipad screen would be ideal."
I tried that excuse to get a bigger tv but SWMBO said just get some glasses ![]() Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Dave,, I use MM plus other's on a I Pad
Just as Davew says
Easy, if i can do it, am sure you could cope !! ![]() Main Brian James Trailer Dealer for South West UK |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Available on amazon uk as well Looks like a handy solution if wifi only ipad/ipod is being used. DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 675 ![]() ![]() |
If your iPhone/ipad doesn't have the 30 pin connector an alternative is the Garmin Glo...
http://www.amazon.co.uk/Garmin-Portable-Gl...amp;sr=8-1 Cheers Steve |
