Home > Off Topic > Mapping Software on Ipad
Projectblue
I have an ipad. I also have 1:50k OS maps in an earlier version of Memory Map. If I buy the app, will I be able to load the maps from pc onto the ipad?
Does anyone else use MM on their iPad? And can someone give an old duffer some step by step guides cos I'm clueless.
Thanks
Post #172847 2nd Oct 2012 11:32pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
You will if the maps are compatible. If your maps don't work with the current version of MemoryMap on your PC they probably won't work on the iPad.
If they do work, you can copy them onto the iPad via the Applications tab in iTunes. http://www.yorkshireoffroadclub.net/
Post #172850 3rd Oct 2012 12:43am
SGH
Do you have wifi model ipad or one on a contract ?
If you only have wi-fi model you might want to get one of these http://bad-elf.com/products/be-gps-1000/ and email them to see if compatible with MM. 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #172857 3rd Oct 2012 6:48am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I have old V4 maps and installed latest Mem-Map app and copied maps to iPad from PC.
All works fine..Smile
Simon
Ps mine is GSM model, bought so it had GPS built in....
Post #172860 3rd Oct 2012 7:03am
Chauch
United Kingdom 2001 Defender 90 Td5 HT Caledonian Blue
If you have the 3G and travel predominantly in mobile signal areas, the free Outside app is superb....
Post #172989 3rd Oct 2012 6:15pm
Projectblue
It's only the wi-fi version. I can tether it to my mobile or, have pda with gps (which I'm currently running MM v4 on, hence having the maps).
trouble is, the old eyesight isn't what it used to be, so the bigger ipad screen would be ideal.
Chauch - I don't and it's precisely for non mobile sig areas that i need the better standard of mapping Very Happy
thanks for the answers so far. Thumbs Up
Post #173497 6th Oct 2012 1:13am
SGH
"trouble is, the old eyesight isn't what it used to be, so the bigger ipad screen would be ideal."
I tried that excuse to get a bigger tv but SWMBO said just get some glasses Rolling with laughter 993 Varioram - Guards Red
Post #173511 6th Oct 2012 7:59am
TJ101
Dave,, I use MM plus other's on a I Pad
Just as Davew says
Easy, if i can do it, am sure you could cope !! Rolling with laughter California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #174230 8th Oct 2012 11:17pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Available on amazon uk as well
Looks like a handy solution if wifi only ipad/ipod is being used.
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #204979 24th Jan 2013 3:58pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
If your iPhone/ipad doesn't have the 30 pin connector an alternative is the Garmin Glo...
http://www.amazon.co.uk/Garmin-Portable-Gl...amp;sr=8-1
Steve
Post #205021 24th Jan 2013 6:59pm
