![]() | Home > Technical > Why don't the front swivels have a rubber gaiter/cover? |
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 ![]() ![]() |
They get covered in crap and wear out!
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
The later ones are supposedly Teflon coated
Because, on the whole, they're more trouble than they're worth. They're very exposed and so easily damaged. The slightest bit of damage lets water in, which is then held against the swivels causing rust and they wear out even quicker.
They also make it more difficult to detect leaking seals, although that's less of an issue with the grease used these days. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
There used to be a company that produced rubber gaiters to fit over the swivels but as has already been stated they and their leather, laced up counterparts tend not to be 100% waterproof and so trap moisture and muck. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
I used to have the leather gaiters on my old 90 (I've got the pert numbers at home if you want them) but As was said above, they get a slight tear in them (which you don't notice), then after a while the seals start to leak.... so you remove the leather gaiter and find it full of silt and stones....
ask me how I know.... so i binned them. |
